Old 12-10-2017, 08:29 PM   #1
rboyle
rboyle's Avatar
Liked 598 Times in 164 Posts
Default SBC Oiling
Freshening my 350/287 hp motor and the oil pan that was on it looks like a Milodon with a trap door and baffle on the passenger side. I have a 1965 Corvette oil pan and pickup with windage tray, crank scraper and oil pump plate that sandwiches betwwen the pump and rear main cap. Mellings HV oil pump too. Any recomendations on which pan and wether to use the scraper or windage tray (Corvette original too) and also feelings on the lifter valley shield.
Thanks in advance
Rich Boyle
Old 12-11-2017, 12:49 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: SBC Oiling
I would not put that high volume pump in it.
The SBC is the last engine that would need one.
Ed Wright 4156 SS/JA
Old 12-11-2017, 12:57 AM   #3
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Standard volume high pressure. Mellings make's billet or standard. Make sure to get the correct pickup.
Mike Rietow is offline   Reply With Quote
Old 12-11-2017, 07:17 AM   #4
carl hinkson
Liked 18 Times in 10 Posts
The Melling 10553 is a good pump STD Volume High Pressure or the 10552 is a 10 % more volume pump which is a pump Ii use a lot of.
I never use a 25 more volume pump.
It really depends where all your clearances are !!!!
carl hinkson is offline   Reply With Quote
Old 12-11-2017, 08:40 AM   #5
richie 2
Liked 205 Times in 93 Posts
a scraper custom fit to the crank is worth the effort. the bigger the pan the better. corvettes pan and its trap door is great. be safe with the amount of oil. lifter valley tray to keep the hot oil off the intake.
Old 12-11-2017, 10:30 AM   #6
SDT1DYI
Liked 456 Times in 148 Posts
As well, consider working on controlled oil return to the pan.
Steve Teeter STK 6380
SDT1DYI is offline   Reply With Quote
Old 12-11-2017, 12:53 PM   #7
randy wilson
Liked 22 Times in 22 Posts
Standard stock as a rock oil pump. It's all you need in a sbc.
don,t have one
Old 12-11-2017, 01:21 PM   #8
nhramnl
Liked 358 Times in 83 Posts
What are your feelings about leaving the gallery plug above oil filter out?
Old 12-11-2017, 02:33 PM   #9
Ed Wright
Ed Wright's Avatar
There ya go! I never used high pressure. 45/50 is plenty if everything else is right.
I have run 40 psi for years. I have a rear main cap, tapped for a hose to an oil pressure gauge for testing pressure. I just drop the pump into my parts washer, hooked to an electric drill. What I see there is always what I see in the car.
I have one of Allen Sherman Sr's low volume pumps in mine right now.
Old 12-11-2017, 06:10 PM   #10
carl hinkson
That would be a good thing, It would make a mess in a hurry !!!
