Liked 18 Times in 10 Posts
The Melling 10553 is a good pump STD Volume High Pressure or the 10552 is a 10 % more volume pump which is a pump Ii use a lot of.
I never use a 25 more volume pump. It really depends where all your clearances are !!!! Last edited by carl hinkson; 12-11-2017 at 06:11 PM. |
Liked 205 Times in 93 Posts
a scraper custom fit to the crank is worth the effort. the bigger the pan the better. corvettes pan and its trap door is great. be safe with the amount of oil. lifter valley tray to keep the hot oil off the intake.
Liked 358 Times in 83 Posts
Liked 880 Times in 311 Posts
I just installed a new set of steel caps(replaced the burned up set) and line bored the block as well as going another .010 oversize to rid the cylinder walls of scratches. Someone tried to use the newest speed trick of leaving that plug out. I think he broke the cam in at the shop and then hot lapped. It ran the heat race and it didn't make the full 25 laps of the main. Man, the filter was real clean when I cut it open.
Adger Smith (Former SS) |
#6 | |
Also rebuilt an old 283 from back in the early 60 and back then the oil filter was an option the engine had over 60000 miles on it but the crank was not as bad as I thought it would be. I did get rid of the big welch plug the covered where the filter went on and put a plugged oil filter adapter on. How many people say you will not have oil pressure if you leave that plug out, LOL |
