Old 06-05-2017, 08:05 AM   #1
Mike Fuller
Liked 198 Times in 79 Posts
Default Weather station ET predictor suggestions
My system just died and I need some opinions on what everyone feels about the available systems.
Mike Fuller 396 STK
3961 SS
Old 06-05-2017, 10:04 AM   #2
Hacksaw
Liked 310 Times in 174 Posts
Default Re: Weather station ET predictor suggestions
I use a handheld Computech. Find it user friendly and accurate in the predictions.
Old 06-05-2017, 11:35 AM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have a PerformAIRE Eclipse, which a lot of my fellow racers swear by but I swear at. I routinely run 0.2-0.3 under the devices prediction.
Here are the predictions and my ETs from last Sunday:
13.18/12.858
13.14/12.835
13.146/12.817
I burned hours trying to come up with a number to subtract from the machine for my dial, but If I had ignored it and paid more attention to the free time slip I would have just dialed 12.80.
Dale Shearon
68 Mustang 6394
Old 06-05-2017, 03:12 PM   #4
Ed Wright
Ed Wright's Avatar
Crew Chief Pro software in your laptop. Enter your weather data along with your runs, after three entered at a given track, it will predict dead nuts, if your car repeats well.
Ed Wright 4156 SS/JA
Old 06-05-2017, 04:04 PM   #5
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Do you use a different data file for each track?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 06-05-2017, 04:43 PM   #6
Mike Jones
Liked 684 Times in 289 Posts
13.18/12.858
13.14/12.835
13.146/12.817
I don`t find my PerformAire to be much help predicting ET, either.
Thought it was just me
Guess I`m not alone.
Thanks
Mike A114
Old 06-05-2017, 04:44 PM   #7
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I do.
Ed's statement about 'three runs' is a little misleading. The software only predicts ET based on one single run that you choose as your base.
Sometimes I'll flip it through a couple different 'base' runs to see if the predictions match.
I've spent a lot of time analyzing runs and tweaking the formulas, but the stock ones are pretty darned good. Probably gotten myself lost more than I've helped.
S/ST 51
S/C 53
Old 06-05-2017, 04:48 PM   #8
Ed Wright
Ed Wright's Avatar
It asks you to. If your car dead hooks everywhere, I would think it would not matter. I just follow the instructions. Been married 52 years, learned to do that.
Old 06-05-2017, 07:51 PM   #9
Ed Wright
Ed Wright's Avatar
Originally Posted by Lenny5160 View Post
I do.
It does recommend having three runs, it does have you put up a base run. My guess is it looks at the changes between previous runs to reference how your car responds to weather changes.
It does a better job that anything else I have used. It will predict from one base run. Predicts mine closer if I have a couple other runs.
Thinking one run is all is needed is saying every car will pick up, or slow down, the same with the same weather change. They don't.
Old 06-06-2017, 08:30 AM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,930 Times in 580 Posts
I have the Perform Air computer based weather station. Race works software is easy to use and seems to be right on the money with my car. It takes a bit to get used to the program and how to get it set up. The price is good and they have good support. I would recommend this system. I don't have the paging option but you can add it on later. One thing about the prediction software is good info in and good info out. I had a hand held for years that was good and it died on me. The computer based is much better.
Mike Pearson 2485 SS
