Old 06-05-2017, 03:12 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Weather station ET predictor suggestions
Crew Chief Pro software in your laptop. Enter your weather data along with your runs, after three entered at a given track, it will predict dead nuts, if your car repeats well.
Ed Wright 4156 SS/JA
Old 06-05-2017, 04:04 PM   #2
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Do you use a different data file for each track?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 06-05-2017, 04:44 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I do.
Ed's statement about 'three runs' is a little misleading. The software only predicts ET based on one single run that you choose as your base.
Sometimes I'll flip it through a couple different 'base' runs to see if the predictions match.
I've spent a lot of time analyzing runs and tweaking the formulas, but the stock ones are pretty darned good. Probably gotten myself lost more than I've helped.
S/ST 51
S/C 53
Old 06-05-2017, 07:51 PM   #4
Ed Wright
Ed Wright's Avatar
Originally Posted by Lenny5160 View Post
I do.
It does recommend having three runs, it does have you put up a base run. My guess is it looks at the changes between previous runs to reference how your car responds to weather changes.
It does a better job that anything else I have used. It will predict from one base run. Predicts mine closer if I have a couple other runs.
Thinking one run is all is needed is saying every car will pick up, or slow down, the same with the same weather change. They don't.
Old 06-06-2017, 08:30 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,929 Times in 580 Posts
I have the Perform Air computer based weather station. Race works software is easy to use and seems to be right on the money with my car. It takes a bit to get used to the program and how to get it set up. The price is good and they have good support. I would recommend this system. I don't have the paging option but you can add it on later. One thing about the prediction software is good info in and good info out. I had a hand held for years that was good and it died on me. The computer based is much better.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 06-06-2017, 10:50 AM   #6
btrc
Liked 84 Times in 42 Posts
Mike,
What do you use for the comparison base. DA, ALT A, Barometric pressure, ??
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 06-05-2017, 04:48 PM   #7
Ed Wright
Ed Wright's Avatar
It asks you to. If your car dead hooks everywhere, I would think it would not matter. I just follow the instructions. Been married 52 years, learned to do that.
Old 06-08-2017, 01:24 PM   #8
cad
cad's Avatar
Liked 91 Times in 51 Posts
My buddy does use a unique database for each track.
