Old 04-16-2017, 05:08 AM   #1
Hudlow66
Hudlow66's Avatar
Default A better "glue" for your rim-to-slick mounting
Has anybody found a better adhesive than the Permatex Hi-Tack, when mounting their slicks without screws? Ive got new rims and was thinking about going screw-less. Mainly because I hate the idea of drilling on my new rims. They're bias Hoosiers 26X8's on a 15X8 rim, if that makes any difference. Usually run (about) 16lbs, for air pressure. Also, currently running tubes and toying with the idea of leaving them out, this go around. Would "that" make a difference in going screw-less or not. Thank you! I'm a bit of a newbi, when it comes to small tire stuff
Phil Hudlow 6678 (S/C, S/G, ET-PRO)
Hudlow66 is offline   Reply With Quote
