Old 04-03-2017, 10:25 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default Bump steer in stock
Just double checking is it legal to use a bump steering kit in stock? We ran into a problem on the alignment with the tie rods being to long and the bump is way off. 4th gen f body. Thanks Tom
Tom Meyer 5240 SS Stock ???
Old 04-04-2017, 12:19 AM   #2
SSDiv6
Liked 1,578 Times in 581 Posts
Default Re: Bump steer in stock
Rule Book
Section 10A, page 7
SUSPENSION, Front
Must retain complete stock front suspension system as produced
by manufacturer for body used, aftermarket tie rods with Heim
joints permitted
. Lower control arm may be machined for larger
shock diameter and mount. Lift kits/travel limiters prohibited.
Sway bar optional. See General Regulations 3:4.
Old 04-04-2017, 07:34 PM   #3
Coleydog
Liked 53 Times in 38 Posts
Well there's your answer, shim that heim joint up or down to control the bump steer
