Old 02-09-2017, 08:55 PM   #1
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Congrats Lindy -- #1
Congrats to Lindy Lindholm for his #1 qualifying position, in a Pontiac powered 2nd gen Bird !
http://www.dragracecentral.com/DRCSt...UMMIT#indextop
Name:	Lindy #1 .jpg
Old 02-10-2017, 01:09 AM   #2
Scott Loge
Liked 145 Times in 32 Posts
Thumbs up Re: Congrats Lindy -- #1
Congrats Lindy! Good run!
Scott Loge is offline   Reply With Quote
Old 02-10-2017, 10:48 AM   #3
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Default Re: Congrats Lindy -- #1
Congrats on the # 1 spot Lindy !
Anyone know what combo is in that '74 Firebird ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 02-10-2017, 11:24 AM   #4
oldskool
oldskool's Avatar
Pontiac 225hp 400--D-port heads--iron intake--750 Q-jet
http://www.nhraeventreg.com/ListEventCatgs.asp?
ey=2017&ec=PC1&cc=8&rn=1
Well, it appears that link no longer works. It was a Winternationals pre-entry list, showing that Lindy claimed a Pontiac 400 engine.
http://www.classracerinfo.com/Engine...1&MAKE=Pontiac
The Class Racer Info site lists that 400 Formula weight @ 3564, with an hp factor of 275. I calculate that to be a 12.96 weigh/hp ratio. So, if I understand the rules correctly(that you can run your natural class or go up or down 1 class, by adding or removing weight), that combo can run I/SA, J/SA, or K/SA.
Looks like 12.50 x 275 = 3438lbs would be the min weight for J/SA. And 13.00 x 275 = 3575lbs would be the min for K/SA. But he's running I/SA, so he weighs less than 3438, according to my math.
By adding weight, I think he could run a D-port 455 in I/SA. hp factor is 306. Weight is 3572. 12 x 306 = 3672. So, looks like it would make I/SA by adding 100lbs.
http://www.classracerinfo.com/Engine...2&MAKE=Pontiac
http://www.classracerinfo.com/Engine...px?ENGINE=2092
http://www.classracerinfo.com/NHRA_Classes.aspx
But, I'm certainly no expert. So, if some of you guys who don't mind, if my calculations, or any of this info, is wrong, please correct it. Since I'm not savvy to all the rules, I'd like to know the details of how to figure all this correctly. Thanks !
Would assume he's running a TH200. But could be a light TH350, I reckin. Don't know.
Old 02-10-2017, 09:03 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
You forgot to add the 170 pounds for the driver weight.................
I/SA = 3470 pounds
J/SA = 3607 pounds
K/SA = 3745 pounds
Bob
Bob Mulry 7516 STK
A & M Motorsports
Last edited by Bob Mulry; 02-10-2017 at 11:26 PM. Reason: Mistake...Got K/SA 100 light..Go Figure
Old 02-10-2017, 11:14 PM   #6
oldskool
oldskool's Avatar
"You forgot to add the 170 pounds for the driver weight.................
I/SA = 3470 pounds
J/SA = 3607 pounds
K/SA = 3645 pounds"
OK, thanks !
So, that means that if the driver weighs more than 170, the car can weigh less. That way, a jockey weight guy will not have an advantage over a big guy. It makes sense.
Old 02-12-2017, 11:32 PM   #7
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Great job Lindy getting # 1 spot
Jake Biermann
