Old 09-04-2016, 04:26 PM   #1
rod
Liked 20 Times in 15 Posts
Default SBC O rings on Dist?
do the O rings really work/help or was this just an MSD gimmick?
your thoughts
Thanks Rod in AZ
rod is offline   Reply With Quote
Old 09-04-2016, 05:36 PM   #2
Woodfin
Liked 288 Times in 109 Posts
Default Re: SBC O rings on Dist?
it is a reasonable question. I have never installed them but on the other hand, I expect it will not hurt anything.
Yet, I am considering all the Chevy engines running without them
Old 09-04-2016, 09:10 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Just a thought,
The stock Chevrolet blocks and distributors are cast iron with tight clearances on the OD & ID.........
MSD is aluminum and is a fits all......
The "O" rings couldn't hurt, but only help getting oil with the least amount of leakage to the lifter galley...
Just my 2 cents,
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-05-2016, 09:04 AM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Originally Posted by Bob Mulry View Post
Just a thought,
Bob
since when?
the 50's and early 60's yeah but after that.....aluminum and plastic (vortecs)
Old 09-05-2016, 02:04 PM   #5
Bob Mulry
Bob Mulry's Avatar
Originally Posted by Tom keedle View Post
since when?
OK OK OK
Don't get all wadded up, I just had a brain fart.............
But everything else is correct......
Do it or don't do, it works either way?????????????????
Again I revert back to.........What could it hurt it could only help
Have fun,
Bob
PS:
My engine oil primer is made from an old cast iron distributor body......
But that's probably 50 years old..........
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 09-05-2016, 08:21 PM   #6
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
I've heard that bronze distributor gears wear less quickly with a little groove in the distributor body and no O rings. That arrangement seemed to help the looks of my bronze gear.
Ron Gusack is offline   Reply With Quote
Old 09-06-2016, 12:06 AM   #7
Adger Smith
Liked 880 Times in 311 Posts
A + Ron
Use the top one and leave the bottom one off.
I like the slot leading the gear contact slightly.
Gear gets a little oil.
Adger Smith (Former SS)
Old 09-11-2016, 04:36 PM   #8
rod
I have always used a slot filed in the bottom, aimed at the dist. gear. and have wondered about using the top O ring and no bottom. once again Adger the experienced one, confirms. thanks guys.
Rod in AZ
