Liked 320 Times in 102 Posts
Just a thought,
The stock Chevrolet blocks and distributors are cast iron with tight clearances on the OD & ID......... MSD is aluminum and is a fits all...... The "O" rings couldn't hurt, but only help getting oil with the least amount of leakage to the lifter galley... Just my 2 cents, Bob
#2 | |
Liked 8 Times in 7 Posts
the 50's and early 60's yeah but after that.....aluminum and plastic (vortecs)
without losers,winning means nothing. |
#3 | |
Don't get all wadded up, I just had a brain fart............. But everything else is correct...... Do it or don't do, it works either way????????????????? Again I revert back to.........What could it hurt it could only help Have fun, Bob PS: My engine oil primer is made from an old cast iron distributor body...... But that's probably 50 years old.......... Just sayin'
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 09-05-2016 at 02:08 PM. |
Liked 7 Times in 6 Posts
I've heard that bronze distributor gears wear less quickly with a little groove in the distributor body and no O rings. That arrangement seemed to help the looks of my bronze gear.
Liked 880 Times in 311 Posts
A + Ron
Use the top one and leave the bottom one off. I like the slot leading the gear contact slightly. Gear gets a little oil.
Adger Smith (Former SS) |
Liked 20 Times in 15 Posts
I have always used a slot filed in the bottom, aimed at the dist. gear. and have wondered about using the top O ring and no bottom. once again Adger the experienced one, confirms. thanks guys.
Rod in AZ |
