Old 06-27-2016, 12:54 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default MSD 2 step issue
I am running an MSD Digital 7 box and a FAST XFI 2.0 system in my Firebird.
The MSD is only being used for firing the coil and the 2 step.
I have the 2 step switch on the brake pedal and utilize an ON/OFF toggle switch to activate it on the starting line. I then flip the switch to OFF when I make the 1/2 shift.
Sunday, the two step activated during the burnout when the toggle switch was in the OFF position. The two step went to 3500 RPM which is where it was set. As this happened once before, I had the MSD dial switch connected in the car and was able to set the 2 step to 8000 to essentially de-activate it. I was able to save the run by leaving on the footbrake w/o the 2 step.
After the first occurrence earlier this year, I re-wired the circuit and installed new switches (toggle and pedal).
Anyone have a similar experience? How could the 2 step circuit be activated w/o power to the switch?
Also, the 2 step stays active when no pressure applied to the brake pedal.
Any help is appreciated.
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 06-27-2016, 01:02 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: MSD 2 step issue
Eliminate the on/off toggle switch and wire it so it activates when the button on the brake petal is pushed, as MSD recommends. Two wires, no more problems! Jim
Old 06-27-2016, 09:10 PM   #3
John Nechiporchik
Default Re: MSD 2 step issue
Thanks Jim. I'll do as you suggested as I don't see any other options with my current configuration. I'm still perplexed as to how the MSD will intermittently activate without power to the circuit. MSD tech has no answer. They did suggest I could send the box in for testing....but indicated due to it's obsolete status, they could not repair it. Rather absurd suggestion. That advise was after waiting 35 minutes on hold on the tech line.
Thanks again Jim. The toggle switch comes out tomorrow.
John
Old 02-04-2017, 01:14 AM   #4
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
If you eliminate the on/off toggle switch what happens when you activate the brake pedal switch down track?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 02-04-2017, 10:08 AM   #5
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
If he`s not going through the brake light switch and with a button in the pedal, slap the brake in a spot next to the button. Either that, activate the 2 step and dump your opponent big time!
Lane Weber
Old 02-04-2017, 02:42 PM   #6
Darrel Goheen
I wouldn't be good enough to remember to step on the peddle beside the switch. I'm guessing it wouldn't be good to activate the 3500 rev limiter at 7000 but maybe it wouldn't do much at all.
Old 02-04-2017, 03:24 PM   #7
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
This almost too easy................
Mount a N/O (normally open) switch that is activated only in 1st gear...
Wire it through the pedal switch, through the shifter switch and then the 2-step......
I don't know what shifter you use but it is pretty easy with a shifter mounted switch....Worst case would be to mount it against the shift arm at the transmission.....
Take a look and figure out what works best.....
Anything that can make a racecar idiot proof is worth the effort...
Just sayin'
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 02-04-2017, 04:10 PM   #8
Darrel Goheen
That's what I'd do but my shifter doesn't get moved after the burnout until I'm done with the run. I'll just put a toggle switch on the dash by the steering wheel. Same place as my Camaro.
Old 02-04-2017, 04:36 PM   #9
Bob Mulry
Bob Mulry's Avatar
You have a PM.......................
Bob Mulry 7516 STK
A & M Motorsports
Old 02-04-2017, 07:43 PM   #10
jimmyparker
Liked 309 Times in 88 Posts
I never put a of/on switch on the two step, normally I set them on about 700lbs brake pressure thinking that if you put 700lbs pressure on the brakes at wide open throttle you will probably wreck anyway. Of course if you are using a manual switch on the brake pedal this doesn't apply, I always use an adjustable pressure switch installed in a brake line.
jimmyparker is offline   Reply With Quote
