Old 06-27-2016, 01:02 PM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: MSD 2 step issue
Eliminate the on/off toggle switch and wire it so it activates when the button on the brake petal is pushed, as MSD recommends. Two wires, no more problems! Jim
Old 06-27-2016, 09:10 PM   #2
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: MSD 2 step issue
Thanks Jim. I'll do as you suggested as I don't see any other options with my current configuration. I'm still perplexed as to how the MSD will intermittently activate without power to the circuit. MSD tech has no answer. They did suggest I could send the box in for testing....but indicated due to it's obsolete status, they could not repair it. Rather absurd suggestion. That advise was after waiting 35 minutes on hold on the tech line.
Thanks again Jim. The toggle switch comes out tomorrow.
John
John Nechiporchik is offline   Reply With Quote
Old 02-05-2017, 08:13 AM   #3
Mike Jones
Liked 684 Times in 289 Posts
John
Does MSD manufacture in China?
Thanks
Mike A114
P/SA
Old 02-05-2017, 09:44 AM   #4
Bill Grubbs
Liked 573 Times in 67 Posts
In America...almost all in El Paso, TX.
Bill Grubbs is offline   Reply With Quote
Old 02-05-2017, 04:15 PM   #5
jimmyparker
Liked 309 Times in 88 Posts
I had a new MSD coil tagged made in China, shocked to say the least.
jimmyparker is offline   Reply With Quote
Old 02-04-2017, 01:14 AM   #6
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
If you eliminate the on/off toggle switch what happens when you activate the brake pedal switch down track?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 02-04-2017, 10:08 AM   #7
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
If he`s not going through the brake light switch and with a button in the pedal, slap the brake in a spot next to the button. Either that, activate the 2 step and dump your opponent big time!
Lane Weber
Old 02-04-2017, 02:42 PM   #8
Darrel Goheen
I wouldn't be good enough to remember to step on the peddle beside the switch. I'm guessing it wouldn't be good to activate the 3500 rev limiter at 7000 but maybe it wouldn't do much at all.
Old 02-04-2017, 03:24 PM   #9
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
This almost too easy................
Mount a N/O (normally open) switch that is activated only in 1st gear...
Wire it through the pedal switch, through the shifter switch and then the 2-step......
I don't know what shifter you use but it is pretty easy with a shifter mounted switch....Worst case would be to mount it against the shift arm at the transmission.....
Take a look and figure out what works best.....
Anything that can make a racecar idiot proof is worth the effort...
Just sayin'
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 02-04-2017, 04:10 PM   #10
Darrel Goheen
That's what I'd do but my shifter doesn't get moved after the burnout until I'm done with the run. I'll just put a toggle switch on the dash by the steering wheel. Same place as my Camaro.
