Old 06-27-2016, 10:14 AM   #1
Stocker Buick GS
Send a message via Yahoo to Stocker Buick GS
Default OEM Battery location and hold down
In the rule book the it states that OEM hardware can be used too
the hold down in the stock ;location,,, the hold down seem weak ! For the battery hold down is a metal part that catches the bottom of the battery and bolts the tray I have bolted the tray to the core support with 3/8 bolts in the stock location replacing the little bolts that held the tray to the core support will that pass tech looks like it can from GM
Stocker Buick GS is offline   Reply With Quote
Old 06-27-2016, 10:21 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: OEM Battery location and hold down
Several thousand passes like this with that tray and hold down and never a failure.
Old 06-27-2016, 11:21 AM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
It is not that hard to make a strap that goes across the top of the battery and use 3/8" fasteners to hold it down . Then it will pass tech without question .
Old 06-27-2016, 02:12 PM   #4
1320racer
1320racer's Avatar
and the OEM 1968 "little bolts" still fasten the tray to the core support. You're worried about nothing. Oh and your new 3/8" bolts are chinese.
Old 06-27-2016, 03:43 PM   #5
Stocker Buick GS
3/8 bolts made right here in the good old USA went in the back room at my POPS and took some that were their when I was little and I am almost 50 neat box heavy cardboard box with metal corners
Old 06-27-2016, 03:52 PM   #6
1320racer
1320racer's Avatar
Nice, NOS and I'm older and remember those boxes.
Old 06-27-2016, 04:01 PM   #7
Stocker Buick GS
He bought a Blue bins with nuts and bolts from some place full just about any size you could think of wheels studs lug nuts would have been back in 70 -71 when Seattle upside down with no work
Old 06-27-2016, 04:22 PM   #8
Jim Kaekel
Liked 535 Times in 110 Posts
I'm sure NHRA wants the strap across the top of the battery to keep it secure in the event of a roll-over, preventing a short or fire.
Jim Kaekel 3836 STK
Old 06-27-2016, 06:49 PM   #9
1320racer
1320racer's Avatar
You would be incorrect when OEM located batteries are mounted with ALL OEM hold down hardware.
