Liked 468 Times in 71 Posts
They always say take notes and save directions,,,,Oh well I am getting old. I missplaced my directions for my Cloyes timeing chain. Can anybody tell me what the symbols on the crank gear are. I advanced the cam when I rebuilt the motor, now I want to put the timeing straight-up. The symbols on the gear are, " O" the next is,a triangle,and the next is a square. I hope the circle is for the factory set-up,cause thats where I just changed it, and the others are for 2 degrees advanced and 2 degrees retarded
Liked 1,737 Times in 395 Posts
You are correct, the triangle is advance, the rectangle is retard, and the O is straight up. By the way, those key ways usually move the cam 4 degrees, not 2.
Alan Roehrich 212A G/S |
Thanks Alan, you are right on the 4 degrees. I was reading and old How to Hotrod Small Block Chevy book and they were referring to 2 degree bushing in the cam gear. I told you I am getting old.
Liked 30 Times in 17 Posts
Tim,
Make sure that you pull the gear and put it back on the correct keyway that matches the "0" mark. Have seen a few customers that just moved to the other timing mark and the results are not pretty ![]()
Bill Koustenis |
