Old 09-18-2015, 05:56 PM   #1
Bench Racer
Liked 99 Times in 21 Posts
Default Rochester 2GC info
Just doing a little bench racing and looking at the 350 Chevy 250/230 with the Rochester 2GC 1686/1375. I was checking to see if any other of the GM (Buick,Pontiac or Olds) cars ran the big 2 bbl. I didn't look at them all but it appeared only Chevy listed carb. measurements on the NHRA blueprint guide. Was the big 2bbl only used on the 350 Chevy? I would expect Billy Nees or Mark Yacavone, the gurus of the odd and obscure combos to chime in on this one. I have the highest respect for these guys because I love odd and obscure combos too.
Bench Racer is offline   Reply With Quote
Old 09-18-2015, 06:23 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Rochester 2GC info
You can find them on Chevy 400`s as well. They are certainly getting harder to find with the 1.375 venturi. Not sure about BOP.
I agree, Billy and Mark would know.
Alan Peters too.
Mike A114
P/SA
Old 09-18-2015, 06:47 PM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
I believe that the 1969 and 1970 Chev 350 250 were the only engines to use this size carb. I queried the database for the ClassRacerInfo website and they were the only two engines that used a Rochester carb with 1.375" venturi.
There were some Oldsmobile engines from 1969 thru 1972 that used 2-Bbl carbs with 1.313" venturi.
There are no listed carb sizes for the Pontiac 2-Bbl carbs in the Tech Bulletins until 1974.
Old 09-18-2015, 06:59 PM   #4
Mike Jones
Learn something everyday.
Thought the 400 used the large 2GC.
Thanks Dwight.
Mike A114
P/SA
Old 09-18-2015, 07:12 PM   #5
Liked 5,146 Times in 1,964 Posts
Even the 69 Impala 396/265 used the 1.25 carb, strange as that sounds.
Old 09-18-2015, 08:20 PM   #6
Bench Racer
Yeah I noticed the early 400 Chevy and 396 used the smaller carb. From what I could find the 400 and 396 carb was around 12 or so CFM less than the 1969 and I think 1970 model 350's. Wonder how much the difference in CFM was worth?
Old 09-18-2015, 10:04 PM   #7
NORMAN BARNARD
Liked 2 Times in 2 Posts
How many of the 1.375 venturi's do you need? I think i have a couple
in the shed. Also venturi clusters and baseplates left over from the local circle track racers who now are allowed to run holley 4412's.
Now is it true or false, nhra no longer is enforcing the carb. P/number but as long as it meet's dimensional configuration and " original visual design" it's good...... (notice i said original design ).
So with that being said and "untouched rochesters" being harder to find. Why can't the marine carb. (that meets the above specification) be used??? Easier to find (yes, even in the darn) desert and has all the good parts already installed (ok, maybe not all, but it has the "good booster cluster" and comes very darn close on the "fuel curve" needed.
Norm
NORMAN BARNARD is offline   Reply With Quote
Old 09-18-2015, 10:23 PM   #8
Mike Jones
I was told the difference between the big
and small carb is about .5
Mike A114
P/SA
