Old 09-18-2015, 07:12 PM   #5
Liked 5,139 Times in 1,962 Posts
Default Re: Rochester 2GC info
I believe that the 1969 and 1970 Chev 350 250 were the only engines to use this size carb. I queried the database for the ClassRacerInfo website and they were the only two engines that used a Rochester carb with 1.375" venturi.
There were some Oldsmobile engines from 1969 thru 1972 that used 2-Bbl carbs with 1.313" venturi.
There are no listed carb sizes for the Pontiac 2-Bbl carbs in the Tech Bulletins until 1974.
Even the 69 Impala 396/265 used the 1.25 carb, strange as that sounds.
