Old 08-13-2015, 05:59 PM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default battery mounting,kill switch Q?
right at the moment this rambler is a bracket car but I don't want to make it stocker-illegal.
#1 does the trunk battery have to be in a box or can it be bolted to the trunk floor?
#2 I'm running a delco internal reg alt, big red wire gets jumped to one of the regulator connector and off the charge post to which side of the battery cutoff switch?
I'm thinking the battery side of the switch....
Old 08-14-2015, 10:36 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: battery mounting,kill switch Q?
The battery has to be secured by something other than a cloth strap or factory style J hooks. It can be bolted down in a box or bolted to the floor by metal straps. Most use mounting kits consisting of a plate with threaded rods that hold a top plate over the battery. Think Jegs, Summit or Budget Fabrication aka DYI.
The battery cut-off should interrupt the main power circuit to the car so that throwing it kills the engine and all accessories especially the fuel pump.
Battery positive connects to one pole and the line to the car connects to the other. Most of them can be rotated so that they can be mounted upside down if needed. It's just a gate switch and does not really have a battery side that matters. Just wire it so that Push is Off.
The charge wire from that alternator is not connected to the kill switch. This caused me a problem with the alternator draining the battery with the car off so I put a breaker switch in the alternator line in the cabin. It lets me shut off the feed from the alternator when the car is off. I wired my volt meter directly to this breaker. With the car running and the alternator set to charge the gauge tells me battery power. If I throw the switch and break the charge circuit it tells me the alternator output.
Dale
Dale Shearon
68 Mustang 6394
Old 08-14-2015, 11:49 AM   #3
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Originally Posted by FireSale View Post
... It's just a gate switch and does not really have a battery side that matters...
I don't think he meant it that way. I think he's asking, Does the alternator connect to the same side of the switch as the battery, or to the opposite side of the switch?
I'm thinking the same side as the battery, that way when the switch is off there's no chance that the alternator will continue to power the engine and fuel pump. But I don't know for sure, it's been a very long time since I've run a car with a trunk-mounted battery.
Dave Muller is offline   Reply With Quote
Old 08-14-2015, 12:01 PM   #4
FireSale
FireSale's Avatar
That would be correct. I tried connecting my alternator to both sides if the switch to solve my battery drain problem and connecting it to the car side produced run-on. I saw no difference between connecting the alternator to the battery side of the switch and the battery positive itself, so I went with the battery pole because there's more room up there and I'm not sure Tech wants anything but the battery connected to that switch.
If an alternator shuts itself off correctly, it can be connected to the battery side of the shut-off switch. Mine won't.
Dale
Dale Shearon
68 Mustang 6394
Old 08-14-2015, 07:16 PM   #5
Dave Cook
Dave Cook's Avatar
Keep it simple, safe, and NHRA legal, get a double pole disconnect.
Dave Cook is offline   Reply With Quote
Old 08-15-2015, 12:30 PM   #6
DIV3CR
Liked 3 Times in 1 Post
Question Re: battery mounting,kill switch Q?
Which one of the small post do you connect the alternator
charging wire on the 4 post switch?
Thank You
Bob Keller
DIV3CR is offline   Reply With Quote
Old 08-16-2015, 11:02 AM   #7
FireSale
FireSale's Avatar
Thank You
Bob Keller
The one in the link below is similar and has an instruction link. The battery positive jumps to one of the smaller terminals and the alternator connects to the other.
http://www.summitracing.com/parts/mo...a/instructions
Dale
Dale Shearon
68 Mustang 6394
Old 08-16-2015, 11:37 AM   #8
HammondRacing
Liked 6 Times in 4 Posts
If wanting to make Stocker legal battery has to be in stock location. You can run a second battery in trunk but they have to be seriesed together.
HammondRacing is offline   Reply With Quote
Old 08-16-2015, 11:48 AM   #9
Painter
Liked 162 Times in 45 Posts
Series yields 24 volts, I think you mean parallel, positive to positive, negative to negative.
Painter is offline   Reply With Quote
Old 08-16-2015, 12:08 PM   #10
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
There are stockers running a series set-up using 6 volt batteries.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
