Old 07-10-2015, 08:52 PM   #1
DIV3CR
Liked 3 Times in 1 Post
Default Starting line hesitation
I have a 80 Camaro 350 H/SA that I am having a problem
with. When the car leaves it goes 2 ft and it sounds like the engine
cut out for a tenth of a second for the last 6 runs. The 60ft times
are exactly a tenth slower the last 6 runs, at 2 different track But the
mph is the same as before this problem.
I have a 2 step and I tried with it hook up and not hook up, no difference
ANY HELP APPRECIATED
BOB KELLER
DIV3CR is offline   Reply With Quote
Old 07-10-2015, 09:47 PM   #2
Jim Whitehead
Liked 150 Times in 41 Posts
Default Re: Starting line hesitation
More info might help. What RPM do you leave the line at? What is the fuel psi before you stage ? What is the fuel psi when it cuts out? Does it recover Quick or slowly rev back up. Have you had the top lid off the q-jet to look inside? Possible fuel psi regulator problem. Or might be ignition miss
Jim Whitehead is offline   Reply With Quote
Old 07-11-2015, 01:16 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Possible fuel spillover on launch?
Rich Taylor
I/SA - 321
Old 07-11-2015, 08:04 AM   #4
cad
cad's Avatar
Liked 93 Times in 52 Posts
Which carburetor? Qjet or Holley?
Old 07-11-2015, 10:34 AM   #5
Monte Howard
Monte Howard's Avatar
Liked 73 Times in 24 Posts
It's either fuel spill over, bad choke pull-off, or secondary door to loose.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 07-11-2015, 02:40 PM   #6
njk53
If it is a Q-Jet could be spill over from too high of a fuel pressure setting.
Nelson Kowal
Stock 345
Old 07-12-2015, 01:46 PM   #7
DIV3CR
Thank you all for your come backs. The car has a 3700 RPM
chip in the 2 Step. Fuel pressure on line is 6 lb.The engine
recovers quickly. The last run it did it twice one after another.
This is a Danny Ashley Qjet built in 2012 I don't want make any
adjustment to the carb. The carb work great before.
. I removed the top to install plugs in carb because I
am now running a two step.I removed the plugs and used the foot
brake, same thing. I also installed a lifter valley baffle could this
ad to the problem
Thanks for your time
Bob Keller
Old 07-12-2015, 04:07 PM   #8
Monte Howard
Since Danny built it, I am ruling out the air door to loose. I would try a new choke pull-off, I have had several of them go bad and cause the same issue. Pull the vacum hose off and push the arm in, with the arm pushed in hold your finger over the vacum port. Let go your finger off the vacum port and make sure the arm comes out smoothly. If it starts coming out and then hangs up for a second it's bad.
Old 07-12-2015, 04:14 PM   #9
rod butcher
Liked 132 Times in 27 Posts
BOB KELLER
Bob,
Is the brass plate for metering rods in place? If that slips forward when changing metering rods it will bog with spill-over. Also check choke pull-off.
rod
rod butcher is offline   Reply With Quote
Old 07-12-2015, 05:05 PM   #10
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Originally Posted by rod butcher View Post
Bob,
rod
That is the problem which I had...
I did not know that it was there and, when I pulled the secondary rods to measure them to resolve a rich condition, it slipped forward.
I could not understand how a car, which ran fabulously just two weeks before, could now stall after my burnout and hesitate so bad off the line.
As it was my first experience with a Danny Ashley carb, I did not find it until I pulled the top off.
Thomas
NHRA 1959 E/SA
Cdncarnut is offline   Reply With Quote
