Liked 3 Times in 1 Post
I have a 80 Camaro 350 H/SA that I am having a problem
with. When the car leaves it goes 2 ft and it sounds like the engine cut out for a tenth of a second for the last 6 runs. The 60ft times are exactly a tenth slower the last 6 runs, at 2 different track But the mph is the same as before this problem. I have a 2 step and I tried with it hook up and not hook up, no difference ANY HELP APPRECIATED BOB KELLER |
Liked 150 Times in 41 Posts
More info might help. What RPM do you leave the line at? What is the fuel psi before you stage ? What is the fuel psi when it cuts out? Does it recover Quick or slowly rev back up. Have you had the top lid off the q-jet to look inside? Possible fuel psi regulator problem. Or might be ignition miss
Liked 33 Times in 16 Posts
Possible fuel spillover on launch?
Rich Taylor I/SA - 321 |
Liked 93 Times in 52 Posts
Which carburetor? Qjet or Holley?
Liked 73 Times in 24 Posts
It's either fuel spill over, bad choke pull-off, or secondary door to loose.
Monte Howard 3209 STK, 3208 SS |
If it is a Q-Jet could be spill over from too high of a fuel pressure setting.
Nelson Kowal Stock 345 |
#7 | |
Liked 132 Times in 27 Posts
Is the brass plate for metering rods in place? If that slips forward when changing metering rods it will bog with spill-over. Also check choke pull-off. rod |
#8 | |
Liked 56 Times in 31 Posts
I did not know that it was there and, when I pulled the secondary rods to measure them to resolve a rich condition, it slipped forward. I could not understand how a car, which ran fabulously just two weeks before, could now stall after my burnout and hesitate so bad off the line. As it was my first experience with a Danny Ashley carb, I did not find it until I pulled the top off.
Thomas NHRA 1959 E/SA |
