Old 06-18-2015, 05:07 PM   #1
428tom
Default Fox Body mustang more foot brake holding power?
Looking for some for information on what works best for more brake holding power on a fox body mustang stocker set up?bigger wheel cylinder,master cylinder etc...
428tom is offline   Reply With Quote
Old 06-18-2015, 05:59 PM   #2
Tony Corley
Liked 61 Times in 25 Posts
Default Re: Fox Body mustang more foot brake holding power?
Rear disc brakes. Dual caliper rear disc even better.
Tony Corley is offline   Reply With Quote
Old 06-18-2015, 07:48 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Most of the time you just have to move the brake rod hole up about a half to three q quarters of an inch and you can hold the car 3500 against the converter.
Lee Valentine 1661 STK
Old 06-18-2015, 09:51 PM   #4
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,390 Times in 506 Posts
Change the pedal ratio as lee said. I couldn't hold beyond 1800 before I did this and put disc brakes around. I hold at 2800 now pretty easily on two step.
'65 Mustang SS/L & L/SA
Old 06-18-2015, 09:56 PM   #5
Mile High
The 2 step kills some power to make it easier to hold it at the line.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 06-18-2015, 10:41 PM   #6
Eman
Liked 133 Times in 76 Posts
Drum brakes actually hold better then disc, drum brakes are self energizing. Basically as the primary shoe touches the drum and the drum tries to rotate it this in turn forces the secondary shoe harder against the drum.
To increase brake holding power increase wheel cylinder diameter and install all secondary shoes for more friction surface area. If possible find a larger size shoe/drum setup from a larger car that will fit your rear. raise the pedal pushrod to increase pedal ratio.
Every Fox body I've fooled with has marginal brakes at best.
Old 06-19-2015, 07:35 AM   #7
428tom
what about the master cylinder size of the bore when increasing the wheel cly size should i go up in master cly size?
Old 06-19-2015, 11:07 PM   #8
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I can say on my '90 Foxbody with discs all around and a Strange m/c it will not creep...tested to 3500rpm thus far with the Dynamic convertor atm. I have yet to move the pivot point on the brake pedal. No two-step installed yet.
Rich Taylor
I/SA - 321
Old 06-20-2015, 06:10 PM   #9
Tony Corley
I can stall my 94 GT street car to 3800 with the footbrake and factory rear disk brakes. No 2 step. Nothing but an organic pad and an inline brake bias adjuster. If you don't want to spend money for aftermarket rear discs, you can convert your Fox to factory rear discs using components from a 94-04 Mustang. Cheap and easy to do.
Old 06-21-2015, 12:08 PM   #10
Eman
It depends and I know that sounds dumb. Look at basic hydraulic principles and you'll understand further how it will have an effect.
The smaller the MC bore the higher the pressure but smaller the volume. The larger the MC bore the less pressure but more volume. Now on the other end of the line the larger the size of the wheel cyl the higher the pressure exerted because there is more surface area exerting the pressure.
