Old 05-23-2015, 05:27 PM   #1
Gene Daugherty
Liked 9 Times in 4 Posts
Default Which battery?
When using 2 batteries on a stocker (one in the front and one in the rear) does it matter which one is the main battery?
Gene Daugherty is offline   Reply With Quote
Old 05-24-2015, 12:04 AM   #2
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Default Re: Which battery?
I believe it states the one in the front must start the car.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 05-24-2015, 05:55 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Not mentioned in the category rules nor the general regulations.
Rich Taylor
I/SA - 321
Old 05-25-2015, 10:55 PM   #4
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Since I only run the front battery, I have no dog in this fight.
But I am curious how those who are running two batteries, have them wired.
Since the rules require a master shut off switch when you have a rear battery & the master switch must shut down the entire electrical system, how do you wire the batteries with one in front and one in the rear?
My guess is:
Front battery: negative cable to frame & positive cable running to the rear of the car to connect to master switch
Rear battery: negative cable to frame & positive cable to master switch
And then another long cable to get the master switch power back up to the starter
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
