Old 04-13-2015, 06:07 PM   #1
L79racer
L79racer's Avatar
Default mid year corvette front springs?
I need to change my front springs. Car is just too low. Anyone change them from stock ones. These were landrum from my 80 that I cut 1/2 coil off. I can give them a call but would like to know some other options. Thanks.
L79racer is offline   Reply With Quote
Old 04-13-2015, 06:48 PM   #2
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Default Re: mid year corvette front springs?
I've used the Moroso 47160 spring. I always cut off the flat end of the spring, just enough so the spring fits in the upper and lower pockets properly. Usually ends up being just over 1 coil off. Ride height is pretty good with an iron head big block. Might not be the best spring, but has always worked well.
Old 04-13-2015, 07:00 PM   #3
L79racer
L79racer's Avatar
Jeff, I should have added its an aluminum headed small block. I thinks its around 1440lbs front end weight. I think those would be too stiff.
