Old 02-20-2015, 09:57 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Spring rates and wheelstands
All things unchanged with the exception being changing the REAR springs , do you believe a new spring or a stouter spring would make the car more inclined to wheelstand?
The current rear springs were USED and originals when I built the car in 93...they are mono leaf GM , Nova or Camaro circa 68-72 and have been beaten on ever since. I think its finally time for new springs.
The car currently just doesnt seem to respond to shock changes or I.C. changes like it should.
Floaters , ladder bars and 9 inch .
Thanks in advance........
Old 02-20-2015, 10:10 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Spring rates and wheelstands
Longer, softer front springs have always made my cars hook harder, but also wheel stand worse.
Ed Wright 4156 SS/JA
Old 02-20-2015, 10:32 PM   #3
joespanova
I'm sorry Ed.....I should have stated "rear" springs .......but point taken. I also limit my front end travel which has remained relatively constant over the years.............the car WAS very wheelstand prone some time ago but has changed its mind in its aging process.
Old 02-20-2015, 10:42 PM   #4
Ed Wright
Ed Wright's Avatar
I haven't had a race car with leaf springs for so many years, I can't answer. I did have a '69 Camaro I ran C/SM with back under the original tire rules. Had mono leafs with ladder bars. Tried big block Camaro multi leafs, and it was like running on marbles.
No wheel stand problems. LOL
