Liked 224 Times in 87 Posts
Looking at the strange web sight it doesn't state wheel stud hole dia. 1/2" or 5/8" of there disc hat for gm 12 bolt . Aerospace sales both 1/2 or 5/8 . Wilwood looks like only in 1/2 holes ? M/W is a yes . Anybody got any info ?
Liked 11 Times in 8 Posts
I had to drill out my Wilwood hats for the 5/8 studs for a Dana 60. I used a Unibit step drill bit.
Liked 99 Times in 60 Posts
Ken, all strange rotors are for the 5/8" studs. Strange has a sleeve to adapt to 1/2" if needed.
On the Strange web site note all the brake photos show with studs and nuts. If you scan the site for stud options you will set the 1/2" stud kits with "sleeves" I have a Strange brake kit for the Super 10 build with 5/8" studs. I installed a symmetrical end on the 12 bolt housing.
Larry Woodfin 471W |
Liked 333 Times in 180 Posts
put the 5/8 in you will never break a stud in a Stocker or LOW HP SS-- got access to a machine shop enlarge the hats to 5/8 inch-- problem solved
Liked 2,486 Times in 697 Posts
X2.........I have broken 1/2 on HEAVY Stocker and
disaster results ( Especially to the Tree )
Liked 284 Times in 87 Posts
Liked 237 Times in 126 Posts
All the Strange rotors look like they have 10 holes of two sizes. We are talking rotors - disk hats - right? Call them.
Dale |
The above post by Dale is correct. I doubled checked this morning, the rotors I have for the Super 10 have both bolt patterns.
I always find it surprising when you can look at an item yet never catch all the details. When you are looking for one specific fitment [it fit on my 5/8" studs] there was no reason to notice the second set of holes.
photo of Strange brake rotor with dual bolt pattern
Thanks guys. There picture looked like the dual rotor hat bolt pattern had 1/2 and 5/8 slotted holes machined on them for use with both sized studs and for height reductions .
