Old 10-06-2014, 06:22 PM   #1
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Default Wanted: Cap for Holley Billet Distributor
I have a Holley Billet distributor and I need a distributor cap. The distributor cap part number is 899-101. Holley has discontinued their line of ignition products. Checked at Jegs, Summit Racing, and several other places found via a Google search, but all have exhausted their supply of these caps.
The distributor rotor is the same as a 57-80s Chevrolet. The cap is listed as 4 inch diameter short style. It has 2 external hold down screws that are offset slightly so the cap will only go on one way.
Does anyone know of a commonly available cap that will fit this distributor?
Larry Merk
Larry Merk is offline   Reply With Quote
Old 10-08-2014, 01:01 AM   #2
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
Default Re: Wanted: Cap for Holley Billet Distributor
Not sure it was holley but one of the after market sbc distributors used a cap for a 345 international.
outlaw is offline   Reply With Quote
Old 10-08-2014, 09:05 AM   #3
ss wannabee
Liked 7 Times in 7 Posts
Did you try the Holley tech line @ 270-781-9741 for that 899-101? I don't know if that
phone # is still good. I got the number from an old post on another site. The guy had
same problem nearly 10 years ago....and was told to call that number for parts.
Maybe you saw that and tried them already...
ss wannabee is offline   Reply With Quote
Old 10-08-2014, 09:58 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Looked similar to 345 IH,
I would go to old school parts place,where parts guys have been around and can probaly identify by seeing,I 'm sure it probably is a cap that existed and holley used it.
Mike Taylor 3601
Old 10-08-2014, 09:25 PM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
If it uses non-HEI terminals, I believe the one you need is Echlin (NAPA) pn #ECH FA9800. -Al
http://www.napaonline.com/Catalog/Ca...800_0059376552
P.S. Holley was the O.E. mfg. for many I.H. eight cylinder distributor applications.
"That'll never work....."
Old 10-09-2014, 01:22 AM   #6
Liked 5,136 Times in 1,959 Posts
Cap pictured is clip type
Old 10-09-2014, 08:18 PM   #7
Larry Merk
Larry Merk's Avatar
Thanks for the suggestions to all who replied.
We've gone to several local parts houses and gone through the parts books with some of their "seasoned" personnel and looked at quite a few distributor caps. Some are very close, but all were either a bit too tall or the diameter was off by 1/8 of an inch or more. A tech rep from Accel tried to cross reference the Holley part number with no luck.
Attached are a few pictures of the cap with a broken terminal. The cap measures 3 7/8 inches outside diameter at the bottom of the cap, 3 9/16 inches inside diameter at the inside mounting surface, and about 3 inches tall.
Still looking and willing the chase any lead anyone can offer.
ID:	26126   Click image for larger version
ID:	26127   Click image for larger version
Larry Merk
Old 10-09-2014, 09:03 PM   #8
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
The Mallory 208M distributor cap look an awful lot like that one...
http://mallory-ignition.com/cap-dist...-down-red.html
Hope this helps...
Old 10-09-2014, 10:11 PM   #9
FED 387
Liked 333 Times in 180 Posts
hell I would buy a Mallory it just might work--- worse thing can happen is return it or put it on Ebay
Old 10-09-2014, 10:48 PM   #10
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
i have the same dist and will need a cap soon, if memory serves me correct its the same as a AMC 8 cyl screw down cap with hei terminals. For some reason im thinkin early 80's jeeps with the 8 cylinders but i cant remember for sure. Theyve been discontinued by Holley years ago, i had one new cap but lost it.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
