Old 05-21-2014, 10:14 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default FWD conversions for GT super stock
While we are brainstorming, let's talk about FWD conversations. I am an experience racer and experienced builder with plenty of shop equipment. Have completed and successfully raced many conventional builds. However, taking on a FWD conversion for GT super stock may strongly challenge my experience.
If some of you have done a conversion in house, tell me about your experience.
My thought is, the older cars are becoming harder to find in good condition while the newer cars are easy to find and low in initial cost.
Is there a FWD "core" that is a reasonable construction base that allows sufficient engine & component room?
Larry Woodfin 471W
Old 05-21-2014, 10:30 AM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: FWD conversions for GT super stock
Check www.9500rpm.com website for his Ford Probe conversion.
Also, since you are a GM person, check FJ Smith's website. He has all the frame pieces for the GM FWD conversions.
Old 05-21-2014, 08:10 PM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Also checkout www.brinkracecraft.com, Ashton Hudson's Escort ZX2 SS/CS is in the gallery,many construction pics.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 05-22-2014, 03:00 PM   #4
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
I looked at the build of the SS/CS car and saw they replaced the entire floor. I was under the impression that the stock floor had to be maintained. Looked like modified the firewall as well. More freedom with the entire build than I thought. Wonder what that escort weighed after the build was done.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 05-22-2014, 03:16 PM   #5
SSDiv6
It's all about creativity and whom inspects the car...
FRAME
Frame or subfloor must be stock for body used. Subframes on
unibody cars may be joined under car.
FIREWALL
Alterations prohibited. Firewall coverings prohibited.
FLOOR
Removable floor section for transmission/shifter installation
permitted; restricted to 6 square feet (2 x 3 feet, 1 x 6 feet, etc.) of
steel material identical to area removed. Stock floor may be
sectioned where rear framerails have been narrowed. Area between
framerails must be stock floor, in original location.
Area between
new rear framerails (from four-link crossmember rearward only) and
body may be replaced with material equal to or heavier than
original; must be in original location. All other floor material must be
stock and in original location.
Theses excerpts are straight from the rule book...
Old 05-22-2014, 03:57 PM   #6
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I went through that build link too and it didn't look like an NHRA legal GT car.
Dale
Dale Shearon
68 Mustang 6394
Old 05-22-2014, 04:16 PM   #7
JHeath
JHeath's Avatar
The rulebook allows a few more modifications in Modified Stock, compared to the FWD GT conversion. I don't have a rule book in front of me, but at least on the firewall, it can be replaced, I believe there is a spec as to where it should be mounted. Not sure about the floor.
Jerry Heath
I/S '93 Cobra
Old 05-22-2014, 04:33 PM   #8
SSDiv6
You are correct about the firewall, however, it is supposed to resemble the OEM firewall. The floor must be OEM.
FIREWALL
Firewall may be recontoured for distributor or magneto clearance
only, and must be properly refinished. The lower portion of the OEM
firewall may be replaced with steel of equal or greater thickness
than OEM. Chevy Cavaliers, Pontiac Grand Ams and Sunfires, and
Ford Escorts may have firewall replaced or relocated, provided the
measurement from the rear of the radiator core support to the
firewall is 34 inches maximum.
For Chevy Cobalt the radiator core
support to the firewall is 33 inches maximum. For all others
vehicles, firewall must be in the original location. A complete onepiece
steel firewall that resembles OEM must be installed, welded
in place, and sealed from the driver compartment. The firewall must
extend to and attach to the floor.
The firewall and mid-plate must be
two separate pieces. All motor plates, mid-plates, etc. must be
separate from and may not be attached to the firewall. Additional
alterations prohibited. Engine must not touch firewall. Firewall
coverings prohibited. See General Regulations 7:4.
FLOOR
Stock mandatory. Floor-mounted clutch/brake pedals permitted.
Headers must fit under stock floor location. The stock framerails
from the firewall to the radiator support must retain stock
attachment configuration, stock location, and stock dimensions.
Frame may be notched for header clearance.
Old 05-22-2014, 05:20 PM   #9
FireSale
FireSale's Avatar
There is an OEM floor pan under the fabricated floorboard. It's Modified Stock. Still don't know if you can do all that to a car.
http://www.brinkracecraft.com/Galler...1/P2189248.htm
Dale
Dale Shearon
68 Mustang 6394
Old 05-22-2014, 09:42 PM   #10
71mavlouisville
71mavlouisville's Avatar
Liked 28 Times in 1 Post
Did not build car for GT, modified and super modified, OEM floor is in place as per rules, we put the bars above the floor, which isn't appealing, so then fab a "sub floor" for aesthetics only, I left the area under the seats open so anyone can see the original floor, the firewall can be replaced and relocated to 34" from radiator support, for escorts and cavaliers, diff for cobalts, it does not have to resemble stock, as a fwd firewall has way too many holes in its stock form and would look terrible, it does have to be steel, the mid plate has to be separate and not part of firewall, I am a long time modified guy, it is very tricky to build a FWD conversion, I did not understand why all the allowances were made either until I built one, you are making a RWD where nothing was before
Ashton Hudson SS/CS 4373
71mavlouisville is offline   Reply With Quote
