Liked 99 Times in 60 Posts
While we are brainstorming, let's talk about FWD conversations. I am an experience racer and experienced builder with plenty of shop equipment. Have completed and successfully raced many conventional builds. However, taking on a FWD conversion for GT super stock may strongly challenge my experience.
If some of you have done a conversion in house, tell me about your experience. My thought is, the older cars are becoming harder to find in good condition while the newer cars are easy to find and low in initial cost. Is there a FWD "core" that is a reasonable construction base that allows sufficient engine & component room?
Larry Woodfin 471W |
#2 | |
Also, since you are a GM person, check FJ Smith's website. He has all the frame pieces for the GM FWD conversions. |
Liked 370 Times in 101 Posts
Also checkout www.brinkracecraft.com, Ashton Hudson's Escort ZX2 SS/CS is in the gallery,many construction pics.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 5 Times in 2 Posts
I looked at the build of the SS/CS car and saw they replaced the entire floor. I was under the impression that the stock floor had to be maintained. Looked like modified the firewall as well. More freedom with the entire build than I thought. Wonder what that escort weighed after the build was done.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#5 | |
FRAME Frame or subfloor must be stock for body used. Subframes on unibody cars may be joined under car. FIREWALL Alterations prohibited. Firewall coverings prohibited. FLOOR Removable floor section for transmission/shifter installation permitted; restricted to 6 square feet (2 x 3 feet, 1 x 6 feet, etc.) of steel material identical to area removed. Stock floor may be sectioned where rear framerails have been narrowed. Area between framerails must be stock floor, in original location. Area between new rear framerails (from four-link crossmember rearward only) and body may be replaced with material equal to or heavier than original; must be in original location. All other floor material must be stock and in original location. Theses excerpts are straight from the rule book... |
#6 | |
Liked 237 Times in 126 Posts
Dale
The rulebook allows a few more modifications in Modified Stock, compared to the FWD GT conversion. I don't have a rule book in front of me, but at least on the firewall, it can be replaced, I believe there is a spec as to where it should be mounted. Not sure about the floor.
#8 | |
FIREWALL Firewall may be recontoured for distributor or magneto clearance only, and must be properly refinished. The lower portion of the OEM firewall may be replaced with steel of equal or greater thickness than OEM. Chevy Cavaliers, Pontiac Grand Ams and Sunfires, and Ford Escorts may have firewall replaced or relocated, provided the measurement from the rear of the radiator core support to the firewall is 34 inches maximum. For Chevy Cobalt the radiator core support to the firewall is 33 inches maximum. For all others vehicles, firewall must be in the original location. A complete onepiece steel firewall that resembles OEM must be installed, welded in place, and sealed from the driver compartment. The firewall must extend to and attach to the floor. The firewall and mid-plate must be two separate pieces. All motor plates, mid-plates, etc. must be separate from and may not be attached to the firewall. Additional alterations prohibited. Engine must not touch firewall. Firewall coverings prohibited. See General Regulations 7:4. FLOOR Stock mandatory. Floor-mounted clutch/brake pedals permitted. Headers must fit under stock floor location. The stock framerails from the firewall to the radiator support must retain stock attachment configuration, stock location, and stock dimensions. Frame may be notched for header clearance. |
There is an OEM floor pan under the fabricated floorboard. It's Modified Stock. Still don't know if you can do all that to a car.
http://www.brinkracecraft.com/Galler...1/P2189248.htm Dale
Liked 28 Times in 1 Post
Did not build car for GT, modified and super modified, OEM floor is in place as per rules, we put the bars above the floor, which isn't appealing, so then fab a "sub floor" for aesthetics only, I left the area under the seats open so anyone can see the original floor, the firewall can be replaced and relocated to 34" from radiator support, for escorts and cavaliers, diff for cobalts, it does not have to resemble stock, as a fwd firewall has way too many holes in its stock form and would look terrible, it does have to be steel, the mid plate has to be separate and not part of firewall, I am a long time modified guy, it is very tricky to build a FWD conversion, I did not understand why all the allowances were made either until I built one, you are making a RWD where nothing was before
Ashton Hudson SS/CS 4373 |
