Old 12-30-2013, 10:37 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default LS1 Accumulator
i plan on adding an accumulator to my LS1 this winter. i have no experience with the LS engines. Where is the best place to add the accumulator into the system? is there an oil port up front of the block?
Thanks
Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 01-01-2014, 11:09 AM   #2
SuperStock 1890
SuperStock 1890's Avatar
Default Re: LS1 Accumulator
The LS pulls the oil to the pump in the front and sends it down the block to the oil filter, then up the back of the block to the lifters and then the mains. At the top of the block in the back there is an oil port. You will need a metric size fitting. Autometer has them. If I remember right it is 16 x1.5 thread.
You don't know what you don't know yet.
SuperStock 1890 is offline   Reply With Quote
Old 01-01-2014, 09:10 PM   #3
Ian Hill
Ian Hill's Avatar
wow, thanks. kind of makes it seem a bit silly to add a remote oil filter to the front of the engine plate! The fitting in the top of the block, at the rear has already been converted to a -4 jic fitting for oil gauge reading. i will add a T here!
thank you for your help
Ian
Ian Hill
Old 01-02-2014, 01:46 PM   #4
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
I've always seen the port on the driver side front used.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 01-02-2014, 02:55 PM   #5
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
If you are using the stock or remote filter off the pan. I would use the front galley in this picture.
The Trailblazer SS SUV have a honorable oil pan and need an accumulator to keep from sucking air.I came up with a kit to help a few friends and that is where they have run theirs.
Front is the Pre filter and the rear (hard to get to) is post filter.
Hope this helps.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
