Old 12-20-2013, 01:32 PM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Question Quadrajet I.D. ?'s
I recently got an OEM Mopar small block intake - 4100340, that had a Quadrajet bolted to it. Don't know if it is original to the intake (Mopar did use them on trucks for a few years), but was wondering what it is and if it's worth anything as a core.
It's a bit dirty, but what I found so far is:
* 32747 and 34712 on the secondary air doors.
* 29909 on secondary throttle blades
* 6058 (?) on bottom middle of baseplate between all the blades. (Date code?)
* Quadrajet Mfg. by Carter for GMC on the throttle side of the body.
* Pass. side has a black round adjustment with rich-lean on it. (Choke housing?)
LOCOMOTION Racing
Old 12-20-2013, 01:50 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Quadrajet I.D. ?'s
Q-jet's made by Rochester had the part number stamped on the left side of the main body. Vertically if I recall right and were always the familiar bronze color.
The Carter manufactured Q-Jets were usually greyish in color and were usually a lot softer than a Rochester carb. Screw holes stripped out very easily and they were just a poor substitute for the Rochester.
I rebuilt lots of carbs in my garage days and never thought much of those carbs....
Rich Biebel
S/C 1479
Stock 147R
Old 12-21-2013, 12:38 AM   #3
Myron Piatek
Unhappy Re: Quadrajet I.D. ?'s
Darn. Just a run-of-the-mill Q-jet. Hoped I could get a few bucks out of it. Thank you!
LOCOMOTION Racing
Old 12-21-2013, 06:14 AM   #4
GTX JOHN
I sell the truck carbs for $50 as the have Mopar linkage which is useful.
The ones before 88 are 800 and 89/90 are 750.
