Old 10-06-2013, 11:55 AM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default Clutch assisted or clutchless
I have been running a old jerico clutch assisted trans in my SS/I camaro. I shift it cluchless. No issues except on the graph the rpm"s spike on the gear change. Was told this is because the clutch assisted trans goes thru a neutral gate on the shift. Does this not happen with a clutchless trans.? Looking to buy a new trans. and was thinking of going with a true clutchless version.
Jim Hawkins is offline   Reply With Quote
Old 10-06-2013, 12:09 PM   #2
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Default Re: Clutch assisted or clutchless
No spike on the clutchless, the split slider stays in one gear untill the slider touches the shifted gear and releaces the previous gear. Will also be a few hun quicker.Tip, just get the split slider on 1-2 ,will stay in gear in high if you let off or clutch it & easyer to drive through pits if you can run it in third.(Jerico)
Jeff Colvert SS/G,F,GT/B 4456
Jeff Colvert is offline   Reply With Quote
Old 10-07-2013, 10:57 PM   #3
Jim Hawkins
Thanks for the response Jeff. May not want full clutchless trans if it can pop out of gear that easily. I have never driven a clutchless trans. My jerico stays in gear on-off throttle, on brakes, whatever in high gear when bracket racing. May check into that 1-2 slider as that's where it spikes the highest.
Old 10-08-2013, 11:38 AM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
Although I like the clutchless trans overall, it is a real pain to drive around in the pits. You hold the shifter in gear with all of your strength, if you let off the throttle or hit a bump (anything that allows the gear to unload) it will jump out of gear and it's pretty much impossible to hold it in. The only way to put it back in gear at that point is to come to a full stop and reengage the shifter, there's always some guy right on your tail when this happens that's pissed off trying to figure out what you're doing holding him up. The other problem that I run into is 1/8 mile racing, I cross the finish line in 4th (I have a 5 speed) which means you only get one shot a hitting the brakes on blipping the throttle at the stripe before the shifter kicks into neutral, don't nurse the illusion that you somehow can strong arm the shifter, ain't going to happen.
Jim Caughlin
SS 6019
Jim Caughlin is online now   Reply With Quote
Old 10-08-2013, 12:29 PM   #5
4speedracer
Liked 10 Times in 6 Posts
I have clutch assisted dr4. Thinking about split case 4speed clutchless from Jerico anybody have any feed back?
4speedracer is offline   Reply With Quote
Old 10-08-2013, 12:40 PM   #6
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Several guys have had problems. I don't have one so no first hand experience. And if your thinking about changing your DR4 over to clutchless even Jerico will tell you its a bad idea. That's what I was told anyway. Save your pennies �� and buy a Liberty.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 10-08-2013, 07:14 PM   #7
Robbie Draughon
Liked 29 Times in 5 Posts
Split slider 1-2 Jerico DR-4. Switched all mine over to this set up and love it. Ran the same trans all year with no issues. 150+ runs. SS/I 69 camaro 302.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
Old 10-08-2013, 09:46 PM   #8
Ed Carpenter
I'll have to call Scott back then!
Ed Carpenter
Old 10-08-2013, 10:04 PM   #9
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
The Westcotts use a Jerico clutchless 4 speed , right?
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 10-09-2013, 02:21 AM   #10
JP
JP's Avatar
5-spd with 4 gears.
JP is offline   Reply With Quote
