Old 09-20-2013, 03:51 PM   #1
JWilson
Default Stock & Super Stock 4-speeds
What is the prefered 4-speed in Stock and in Super Stock?
If I remember correctly, stock was clutch assisted and super stock was clutchless. Is this still correct?
JWilson is offline   Reply With Quote
Old 09-20-2013, 05:10 PM   #2
tj310
Default Re: Stock & Super Stock 4-speeds
SS allowed clutchless, Stock not yet . G force ,Liberty ,Jerico all sell clutch +less ---Trevor
Old 09-20-2013, 10:58 PM   #3
randy wilson
Liked 22 Times in 22 Posts
G-Force, and Jerico sell clutch assisted and clutchless. Liberty clutchless only, but will modify stock trans for clutch assisted. Who's best? Depends on who you talk to. They all work well.
don,t have one
Old 09-21-2013, 12:41 PM   #4
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Liberty makes the Equalizer (clutchless with dual cluster shafts) 5 speed that is legal in Super Stock. Liberty also makes an LSC 5000 (single cluster) and LSC 5100 that are legal in stock. The LSC 5000 and LSC 5100 are very similar in design to the old Doug Nash split clam shell type transmission. We run an LSC 5100 in our CobraJet, but run it in a 4 speed configuration. If you run any of the split clam sheel transmissions as a 5 speed you will have issues. We have had zero breakage problems running the LSC 5100 in 4 speed configuration. More info at http:\\www.libertysgears.com.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 09-21-2013, 12:53 PM   #5
JWilson
I see alot of guys running the Jerico DR4 & CL4. And also the Gforce 101A. Whick looks basically like the Jerico. The Liberty 5100 is also a strong looking trans. Seems like i see most guys running the Jerico down here in the south.
Old 09-21-2013, 01:57 PM   #6
tj310
Jerico had the market cornered for a lot of years. Gforce looks likt a T10
George Wright we run a LSC 500 as a 5 speed , and before that a Nash . Are there specific concerns you could share ? ---Trevor
