Old 07-30-2013, 03:57 PM   #1
Paul Ceasrine
Liked 10 Times in 10 Posts
Default 1965 Plymouth Barracuda
What is it they asked...
1965 Plymouth Barracuda 273/235 HP Commando
Classed in F/SA in 1965 -
Doug Patterson won the F/SA Class at the 1965 NHRA Springnationals.
Then went on to Runner-Up in Junior Stock Eliminator.
In September 1965, set the NHRA National Record.
13.62 @ 102.95 MPH
Old 07-30-2013, 10:27 PM   #2
Default Re: 1965 Plymouth Barracuda
Personal favorite:
Old 07-30-2013, 10:52 PM   #3
Paul Ceasrine
Charley A,
Check out those 'tubes'
In 1965, try finding a Header Company that made a good set of tubular headers for the 273 A-Body......
Old 07-31-2013, 09:15 AM   #4
Charley A,
Guessing they were trying to stay"equal length" and just could not fit it all under the hood. Funny now....way cool then!
Old 07-31-2013, 01:22 PM   #5
Paul Ceasrine
October 1965
NHRA 'F/S' National Record Holder
13.44 @ 103.68 MPH
Old 08-08-2013, 09:04 AM   #6
Rob Ayres
Liked 31 Times in 2 Posts
That 13.62 record was an altitude adjusted record. The actual time the car ran was 13.98 at Bristol. Fred and Doug had a fast little cuda but there was no way those cars would in the 13.60's in 1965. That record was what forced us to move to a 180 hp -273 and run I/SA, and later N/SA. Our first set of headers actually exited in front of the front tires. The small engine compartment forced you to be a little creative with header technology. Then Dougs and Stahl came up with nice designs for the little cars. A pain to install, but nothing was easy with those little cars.
Rob Ayres is offline   Reply With Quote
Old 08-08-2013, 12:06 PM   #7
Paul Ceasrine
Rob,
Weren't they protested because of the use of the controversial
Carter #3447 AFB Carburetor, which was permitted by the NHRA.
The 600 CFM rated unit, that was used on the 1963 '426 Max-Wedge' engine.
The #3447 had a 1 7/16" Primary and 1 11/16" Secondary, and the
273 Cast Iron Intake required the 'secondary' bore hole to be opened up.
That 600 CFM AFB did make a big difference over the 'stock' 500 CFM AFB.
Old 08-08-2013, 01:23 PM   #8
Rob Ayres
I don't remember anything about that. But that doesn't mean it didn't happen. I agree, going to a 600 cfm carb would have helped the little cars a bunch.
Old 08-08-2013, 10:42 PM   #9
Paul Ceasrine
Rob,
Weren't the 1965 - 273/235 HP - Barracuda's listed at #2930 lbs. {Shipping Weight}, which put them a 'hair' under the 12.50 Wt/Hp.
Yet, the NHRA permitted them into the {12.50 to 13.99 Wt/Hp} F/S and F/SA Stock Class in 1965.
Old 08-09-2013, 07:50 AM   #10
Rob Ayres
No, the shipping weight was 2940 lbs which put it at 12.51 lbs per HP. The car was made for the class. If you ever want to check any of the original shipping weights on the older stuff, I have all of the original NHRA classification guides and spec sheets from the 60's.
