Old 07-26-2013, 09:46 PM   #1
dragsterdoug
Default Header stains
Had a valve cover gasket leak oil on one of my headers. What do you guys use to remove the stains? Headers are coated. Thanks, Doug
dragsterdoug is offline   Reply With Quote
Old 07-27-2013, 11:07 AM   #2
Liked 1,918 Times in 432 Posts
Default Re: Header stains
NitroPlate uses Meguiars aluminum polish. It normally removes most small, light, or mild stains. If that will not remove the stains, they may be so deep in the coating that they cannot be removed.
Old 07-28-2013, 01:53 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
aluminum polish and 0000 steel wool
Old 07-28-2013, 04:08 PM   #4
Tim Quintin/Cole s/g
Tim Quintin/Cole s/g's Avatar
what he said^^
Tim Quintin - (driver) Cole Quintin- (Crew Chief
1970 Cuda S/G NHRA DIV 1
1970 Cuda S/ST NHRA DIV 1
Tim Quintin/Cole s/g is offline   Reply With Quote
Old 07-28-2013, 09:22 PM   #5
dragsterdoug
I found some stainless steel polish that worked pretty good with just a rag. Still had to rub some but not bad. I will get some maguirs. Thanks for the response
Old 02-27-2015, 01:18 PM   #6
74fb461
74fb461's Avatar
Do U apply it with the 0000 steel wool then? Ive used a rag before to apply it, but if this works better
74fb461 is offline   Reply With Quote
