Old 02-20-2013, 02:41 PM   #1
Chris Hall
Default 1970 Camaro Stocker
I'm converting my bracket 70 camaro in to a stocker. I'm going with the 350hp 402 combo. I'm new to stock so any info on this combo, good or bad would be great.
Chris Hall is offline   Reply With Quote
Old 02-20-2013, 06:51 PM   #2
rick winchester
Liked 195 Times in 33 Posts
Default Re: 1970 Camaro Stocker
Welcome to stock,its a blast and a pain all at the same time. Many good running 2nd. generation camaros out there ,but none with 402 /350 that I know of. I think you would be better off with the 350/360 Z/28 (325 nhra hp) or the 350/300 (286 nhra hp) . If you dead set on running the 402 you should look at the 402/315 71 combo. Maybe contact Jim Hughes ?. He has a good running 70 Nova 402 if I am not mistaken. He raced a 70/71 camaro Z/28 also. I know that this is not much help,if I were you i would study the tech guides carefully while building the body and then decide on a engine combo. Rick.
Rick Winchester Stk 3277
rick winchester is offline   Reply With Quote
Old 02-20-2013, 07:01 PM   #3
Liked 1,758 Times in 398 Posts
Keith Lynch had a fair amount of success in big block 70 Camaro, however, it was a 402/375, which is still a decent combination, and what I'd run in that car if I were going to run a big block. The LT-1 is a good small block combination, and probably what I'd run if I were going to run a small block. If I were going to run a small block I'd run a 4 speed.
Old 02-21-2013, 12:38 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Chris Hall you have a Private Message
Adger Smith (Former SS)
