Old 01-12-2013, 09:42 PM   #1
Duster 318
Default Externally balanced
Are you allowed to have your motor externally balanced in stock eliminator?
Duster 318 is offline   Reply With Quote
Old 01-13-2013, 06:26 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,193 Times in 975 Posts
Default Re: Externally balanced
Yes, you can even get an external balance SFI harmonic balancer should you need it for a 10 second car....but of course internally balancing the motor will simplify things down the road.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-13-2013, 09:35 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Externally balanced
As mentioned, it is allowed. But aside from the advantage of easier to find neutral/internally balanced dampers flexplates and converters, I was always told that internally balanced assemblies are easier on the crank and bearings. It's probably more relevant to higher rpm combos, but something to consider nonetheless.
Old 01-13-2013, 11:27 AM   #4
Duster 318
ok thanks for the info
Old 01-13-2013, 07:13 PM   #5
Philip Saran
Liked 14 Times in 11 Posts
You can also take a externally balanced motor (such as a 360 SB) and have
it internally balanced (does use more heavy metal). But it can be done.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
