Old 12-23-2012, 12:14 PM   #1
Lonnie Cox
Default A/ARM Snubber question
76 camaro/Small Block Cal tacs with split mono leafs , Moroso 47180 springs in front not cut yet.
My question is do i leave the snubber's: in or remove them.
Thank You as always
Lonnie Cox is offline   Reply With Quote
Old 12-23-2012, 12:52 PM   #2
Billy Nees
Default Re: A/ARM Snubber question
I'd leave the lower snubbers in. Technically, you're supposed to have a snubber of some sort in the upper but I've seen an awful lot of cars that have had them "fall out" over the years and I have put taller ones in my cars to help my RTs.
Some of the newer high $$$ shocks give you the option of travel limiting too.
Billy Nees 1188 STK, SS
Old 12-23-2012, 01:13 PM   #3
Run to Rund
Liked 54 Times in 27 Posts
Check toe in through the front end travel. In A bodies, the toe in gets severe after so many inches of lift, so a snubber can help. Otherwise there could be a lot of tire drag or steering when coming down from the wheelie. You should be able to get around 6" or so with modest toe in change per inch of travel.
Old 12-23-2012, 04:59 PM   #4
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
great answer.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-28-2012, 11:14 PM   #5
Lonnie Cox
Thanks again to everyone
