Old 08-04-2012, 01:16 PM   #1
FED 387
Liked 334 Times in 181 Posts
Question battery cable ???
Need to replace a positive(+) battery cable moving batteries around and the present cable is way too long ---need to be about 6 feet long max----what is the smallest size cable I should even consider using???-- thanx FED387
Old 08-04-2012, 03:07 PM   #2
Joe Toller
Liked 9 Times in 9 Posts
Default Re: battery cable ???
I know weight may play a part here, but I would suggest a 1/0 cable, resistance increases with length. I'd rather my cable be a little heavy, than not make the call because it's not carrying enough juice to turn a hot motor...
Old 08-04-2012, 04:41 PM   #3
FED 387
this is ultimately gonna be a comp car so weight IS a consideration too---not worried bout hot lapping it motor gets cooled down real good--- any other ideas out there??? and I do appreciate your response
Old 08-04-2012, 04:52 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: battery cable ???
If weight is a concern, what about Accel's Lightning cable? Copper clad aluminum and available in 1, 2 and 4 gauge 20' and 100' spools?
Old 08-05-2012, 02:24 PM   #5
camaro 77
this may help you out
camaro 77 is offline   Reply With Quote
Old 08-05-2012, 03:09 PM   #6
FED 387
great chart--- thanx that will explain what size I need---FED387
