Old 06-21-2012, 01:48 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default Msd programmable digital 6
Any one here try a MSD PROGRAMMABLE DIGITAL 6
How did it work?
Any thing to gain on a stock eliminator car with this?
MEXJOE is offline   Reply With Quote
Old 06-21-2012, 04:32 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Msd programmable digital 6
I thought those were not legal for stock, Am I wrong?
Old 06-21-2012, 05:47 PM   #3
Jim Parsons
Liked 197 Times in 32 Posts
I went from an old early 7-AL to the digital -6 and believe I picked up a little. It has built in start retard and best of all it uses rotating pots to set rev- limiters, both top end and launch so you don't have to mess with all the chips. If I remember correctly it has a lower minimum voltage than the others to function correctly.
Personally I like it and have had several other change over.
P.S. The 6 is non programmable which make it legal.
Jim
Jim Parsons is offline   Reply With Quote
Old 06-21-2012, 06:16 PM   #4
David Lee
this is the legal one right
http://www.msdignition.com/Products/...n_Control.aspx
And this one is not:
http://www.msdignition.com/Products/...ble_6AL-2.aspx
Correct?
Old 06-21-2012, 07:04 PM   #5
T Ketels
I may be out of the loop on this, but from what I remember, the we cannot run the 7531 or any box that has the slew rate controller as it is deemed as traction control. I haven't looked for an updated list lately.
I used to run the Digital 6 Plus and it worked flawlessly - I'm currently putting one in the super stock car once I ever get it finished!
Tim
SS/MA
5017
T Ketels is offline   Reply With Quote
