Old 06-11-2012, 10:24 PM   #1
DIV3CR
Liked 3 Times in 1 Post
Default Hoosier tires
When using Hoosier 30.0/9.0-15 slicks l/w radials and run them
tubless do you screw them to the rim?
DIV3CR is offline   Reply With Quote
Old 06-11-2012, 11:18 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Hoosier tires
I have never
Old 06-12-2012, 12:28 AM   #3
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Hoosier tires
I do. But just because I bought the wheels used and they already had the holes.
2009 V/SA Record Holder
Old 06-12-2012, 11:35 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Hoosier tires
I've run them for years on 10" rims at 21 lbs without screws. They may move a bit initially and when I swap them side-to-side the move back a bit. Not enough to worry about and they usually settle down anyway. High HP or low tire pressures may cause issues, but just put a mark on the tire relative to the valve stem and watch for movement.
Old 06-12-2012, 06:32 PM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
No tubes. No screws here...... 1.38 60' 3500lb
Old 06-12-2012, 08:49 PM   #6
DIV3CR
Thanks guys you have been a great help.
Old 06-12-2012, 09:17 PM   #7
72Malibu
72Malibu's Avatar
1.319 best, 1.327 a couple weeks ago, no screws @ 3680 lbs.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 06-12-2012, 10:09 PM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Ran Hoosier 30.0/10.0 Radial for 9 seasons going through 3 sets a season and none were ever screwed, running a 1.288 best 60 foot @ 3880 lbs.
Old 06-13-2012, 04:36 AM   #9
Bobby Zlatkin
Bobby Zlatkin's Avatar
I use them with no screws. When I mount them I really wipe the part of the rim where the bead sits real clean and dry with lacquer thinner and do the same to the tire.
They won't move although, later, when you go to dismount them you may have a little trouble breaking them loose.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 06-13-2012, 05:20 AM   #10
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I've never needed to use the screws on the 8-inch rims at 25 PSI, although I'm not running a "high-horsepower" combination.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
