Old 06-04-2012, 05:17 AM   #1
Ben Kallies
Default Leakdown Testing
Question: When performing a leakdown test on an engine, how does one stop the 100psi of air pressure from pushing the piston back down in the hole, which in turn moves the crank/cam, opening up the valve, and letting all of the air you just pumped into the cylinder? I tried reinstalling all of the other spark plugs, along with putting the trans in gear, but it still pushes the piston down enough to open the valve back up.
Answer:?
Thanks,
-Ben
Ben Kallies is offline   Reply With Quote
