Banned
Those Sun Leak Down testers are like Gold I have two one in the shop and the one in the trailer. When there is a auction in the area I look for them. As I remember no mater what the input pressure is the only put 30 or 60 psi into cylinder.
Thanks to everyone for all the info. Chuck
That's what I use. Have had mine for forty years. (got it in 1972) Still works like new. Just needed a new hose once.
Ed Wright 4156 SS/JA |
Liked 333 Times in 180 Posts
Yep had mine bout that long too-NO its not for sale---one more thing remember to RESET TO ZERO the % gauge before you go do the next cylinder( part of the attach/ unattach/attach tap the lense LIGHTLY routine---REPEATABILITY is what counts here---this is not rocket science merely comparing one cylinder to another looking/hearing for wear or malfunctions/damage---we always leak a new engine before start up/after initial start up to get a baseline for the future to see how much wear we really are getting as we put runs on the car--but we do leak it at the end of EVERY day racing just to see whats going on-FED387
It's also good to check for leaks with the piston all the way down (with rockers backed off). Just a little more information.
Liked 346 Times in 126 Posts
Good day, can a leak down test be done on a cold engine?
Sure.
Engine temp really does not come into play here!!!!!
