Old 05-11-2012, 05:02 AM   #1
Johnny McDermott
Default 10 bolt pinion yoke on a 12 bolt pinion gear?
Hello,
What is the advantage of using a 10 bolt yoke on a 12 bolt gear. I was told that there was a strength advantage. Is this true? I really didn't know that they were interchangeable.
What is to be considered? Are there any other related parts that need to be changed?
Thanks,
Johnny
Johnny McDermott is offline   Reply With Quote
Old 05-13-2012, 08:39 PM   #2
Liked 5,146 Times in 1,964 Posts
Default Re: 10 bolt pinion yoke on a 12 bolt pinion gear?
Originally Posted by Johnny McDermott View Post
Hello,
Thanks,
Johnny
It seems to me I did that about 20 years ago. It wasn't for strength, but more for availability. I think you have to research an oddball pinion seal.
Old 05-18-2012, 04:21 PM   #3
bottombulb
The pinion seal that works is from a mid-80's Chevy full size 4wd 1/2 ton for the front differential.
bottombulb is offline   Reply With Quote
Old 05-18-2012, 04:32 PM   #4
Jim Cimarolli
Liked 166 Times in 46 Posts
On a related subject:
I have heard that there is an available pinion bearing, or bearings, that will allow you to put 12 bolt GM car gears in a 12 bolt pickup housing.
Has anyone got any info on such a swap?
Thanks
Jim Cimarolli is offline   Reply With Quote
