will mounting it to the slip yoke on the transmission work ok?
Chad Rhodes 2113 I/SA |
Liked 275 Times in 76 Posts
The amount that your suspension moves the slip yoke, away from the sensor may make it unreliable.
Sean
that's exactly my concern
Liked 4 Times in 1 Post
I have mine mounted on the slip yoke with no issues whatsoever. The kit gave us no alternative.
Tony Curcio 1860 STK |
Liked 26 Times in 13 Posts
It will also depend on what sort of sensor your DA is using. If it is a magnetic reed-switch type it will probably be unreliable as the distance between the sensor and the magnets change. If it is a Hall-effect sensor, it likely will work just fine. It also depends on the strength of the magnets in your ring.
Bill Harris ex 2172 STK ex 2272 S/S |
I have installed a few on slip yoke with no problems.
