Old 04-18-2012, 09:20 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default No Power??
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 04-18-2012, 09:25 PM   #2
Pvt Parts
Pvt Parts's Avatar
Default Re: No Power??
Originally Posted by deuces wild View Post
Ok tried again. New battery. This engine acts like it has no power. Sounds awesome in the pits,in the water, and on the starting line. Dump the clutch and it kills it. Won't pull any rpm. Checked everything. All checks out. Only thing I changed over winter was I had pat redo mad box. Ideas??????
Maybe at this point some dyno time might be a good investment.????
Old 04-18-2012, 09:34 PM   #3
Liked 1,737 Times in 395 Posts
Is that supposed to be "MSD box"?
Old 04-18-2012, 10:03 PM   #4
Alan Warman
Ed
What did you find wrong with the motor. When I talked to you in San Antonio, you said the leak down and the compression test didn't look good.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 04-18-2012, 10:21 PM   #5
Ronald Urquhart
Liked 77 Times in 39 Posts
Cool Re: No Power??
I had a problem like that years ago when I had my chevy ll after weeks of tearing my hair out turned out to be a bad msd box. It didnt miss breakup just no power going down the track.
Ronald Urquhart is offline   Reply With Quote
Old 04-19-2012, 02:08 AM   #6
Jeff Lee
Jeff Lee's Avatar
A really bad ground? New MSD box incorrectly wired on installation? Can you borrow another box after you check your grounds and installation?
Jeff Lee 7494 D/S '70 AMX
Old 04-19-2012, 07:39 AM   #7
jim morgan
Liked 52 Times in 9 Posts
Replace pickup with a known good one. better yet put new one on.
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 04-19-2012, 08:39 AM   #8
Sean Marconette
Sean Marconette's Avatar
Liked 274 Times in 76 Posts
Is there a chance that the polarity to the distributor pickup was switched? That is all it takes to do some strange things with the MSD. The car will run fine, until going down the track, and then it will act like the rev limiter has been lowered. Good luck.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-19-2012, 10:43 AM   #9
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
I agree with Jim, change the pickup. we had that same issue at a race a few yrs ago and change the pickup and the car ran fine!!
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 04-19-2012, 11:49 AM   #10
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Just some random info about MSD's & other high current draw parts...............
The MSD 7AL depending on the resistance caused by the plug gap, high compression, rotor gap, sparkplug wires, load, RPM and anything else that makes it more difficult to fire the plug will raise the amperage requirement for the box.
Your power supply wiring should be capable of passing 15 amps on the positive AND negative side.....
All wiring connections should have crimp fitting (mechanical connection) and be soldered (electrical connection) and be covered with shrink tube to prevent corrosion.....
You MSD box will work perfectly until you the reach the point of needing more amps than your wiring can supply...
Had the same type of problem with a MSD 404 box 40 years ago and learned my lesson regarding resistance in the power AND ground side of wiring..
In the words of Stroker McGurt "If some is good, more is better and too much is just right"
Hope this helps,
Bob
Bob Mulry 7516 STK
A & M Motorsports
