I have rung the spines out of a clutch hub this week. After careful inspection, I have discovered that the disc I bought form Bonninfante has splines that are approx .300 long in the hub. I picked up a disc from Ram and measured the splines in their hub to be approx .420 long. I would like to just replace the hub on the disc without buying a new disc. The flywheel and PP show very little wear. Would like to swap hub for the thicker Ram piece.
Anyone try to mix hubs on discs? Andy Stone ___________________________________________ 1102 A/S 1112 SS/C |
Liked 779 Times in 193 Posts
If it fits, wear it.
Liked 370 Times in 101 Posts
I did the same 10 years ago, sent both pieces to Ram, they switched hubs , not a big deal, thinking it was fairly inexpensive. but Tim Hyatt may be quicker and cheaper.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#5 | |
Liked 418 Times in 96 Posts
Appreciate the info. Thanks.
_________________________________________ Andy Stone 1102 A/S 1112 SS/C |
Liked 20 Times in 15 Posts
i had McLeod change out a center not long ago. theirs was just bolted together. grade * bolts and stop nuts.
rod in AZ |
