Old 01-27-2012, 01:11 PM   #1
Axis Racing
Default Dial in method
As a newb to SS competition, are elemination rounds run like a bracket race with the exception of heads-up if both cars are from the same class?
In other words, the competitor chooses their dial in and can't run under it or a break-out occurs? Or is the dial-in chosen automatically based on qualifying times like some Quick-8 or 16 events use? I'd assume that qualifying sets your position on the ladder, and then it's a bracket race right? Otherwise I'd imaging that there would be way more CIC penalties with guys capable of running 1.0+ under...
Axis Racing is offline   Reply With Quote
Old 01-27-2012, 01:16 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Dial in method
You choose your own dial-in, which can be changed from round to round. Two notes, though:
-You must dial in at or quicker than your class Index. Example, NHRA A/SA Index is 11.00. You can not dial 11.01 or slower.
-A race between two cars of the same class (A/SA vs A/SA) is heads-up, no breakout, first to the stripe wins.
Old 01-27-2012, 07:16 PM   #3
SuperCompDiv3
Get a good weather station and take good notes.
SuperCompDiv3 is offline   Reply With Quote
Old 01-28-2012, 03:30 AM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Dial in method
We all use shoe polish on Sunday....Yes it's a bracket race all but for heads-up runs with same class cars. Qualifying puts you on a "ladder" in witch you are paired up for eliminations.
Old 01-28-2012, 03:37 AM   #5
greg fulk
greg fulk's Avatar
P.S. everybody has their spot where they like to qualify ... you'll learn as ya go.
Old 01-28-2012, 12:08 PM   #6
69Cobra
Liked 2 Times in 2 Posts
Care to elaborate?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 01-29-2012, 09:48 AM   #7
Liked 10,921 Times in 2,257 Posts
My favorite spot to qualify is 128 or above at Indy.
Old 01-29-2012, 12:09 PM   #8
Mike Carr
Mike Carr's Avatar
Originally Posted by 69Cobra View Post
Care to elaborate?
Re: ladder games
Racers will move around the qualifying sheet/ladder for several reasons.
-Move to avoid a heads-up with a faster car
-move to race a heads-up with a slower car
-qualify in the middle of the field.
Example: in a 66 car field, if you qualify #32 or 33, you will get one of the two bottom cars (65 and 66); cars that may be broken, over the Index, having problems, etc. Potential easy run. If you end up #34, you run #1 first round. Win, and you have the 2nd round bye, and, if you get there, the 6th round bye, the bye into the final.
Just a few examples of what can be gained by having a particular spot on the qual sheet/ladder.
P.S. What Larry Hill said, too.
