Old 11-03-2011, 09:21 PM   #1
Stocker
Question valve spring /vs/ cam bushing
In small block chevy , do the cam bushing can handled the 300 lbs valve spring seat pressure and 1000 lb open?
any input ,
thank!
Stocker is offline   Reply With Quote
Old 11-04-2011, 01:56 AM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: valve spring /vs/ cam bushing
It's not the alignment dowel that takes the load........
The correct bolt torque on the timing gear bolts pulls the gear to the face of the cam and friction causes the cam to turn......
The stock type set-up will work fine...
Bob Mulry 7516 STK
A & M Motorsports
Old 11-04-2011, 05:29 PM   #3
Stocker
Sorrry, I am talking of the cam bushing in the block?
Thank,
Old 11-04-2011, 05:51 PM   #4
Liked 1,952 Times in 439 Posts
You mean cam bearings?
If that is your question, then the answer is yes, they will. You do however need to use a real race bearing, preferably a coated bearing. The stock rebuilder/replacement bearings are often not up to the task.
I use the Dura-Bond CHP-8-T.
Old 11-04-2011, 10:01 PM   #5
Stocker
Alan ,yes that is.!
Thank ,
Old 11-05-2011, 11:15 AM   #6
Originally Posted by Stocker View Post
Alan ,yes that is.!
Thank ,
Hope that tells you what you want to know. Honestly, if your block will take it, you should consider at least a big block cam journal core, if not a 54MM or 55MM core.
