Old 08-20-2011, 02:20 AM   #1
Jason Fuller
Guest
Posts: n/a
Red face electric or gear driver rear end lubricator
I have a question as with the legalness of using a stand alone unit to lube the pinion and ring gear.
Is it legal in Stock?
Point is removing the windage from the case and gaining some lost mechanical power back...
I suppose this would work best with an electrical pump...That's what I want to do..
Thank you in advance for the clarification...
Old 08-20-2011, 05:44 PM   #2
Jason Fuller
Guest
Posts: n/a
Exclamation Re: electric or gear driver rear end lubricator
I've received a PM from a "pro" concerning this topic but, what's the concensus on legal or illegal?
Chime in with opinions..Please..
Old 08-21-2011, 02:02 AM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: electric or gear driver rear end lubricator
stock is not a "pro" class,obviously not legal, dumb idea , probably not enough there to bother with, try a scraper for the ring gear, just find someone with a ring and pinion dyno!!, your time would be better spent on other things.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-21-2011, 03:50 PM   #4
Pvt Parts
Pvt Parts's Avatar
Not really legal since essentially the center section is a "wet sump" design for the R&P and your proposal would be converting it to a dry sump. You might get by however with a heater like Glidden and some of the Pro Stocks used to run. Plug it in between runs and it heats and thins the oil. But with today's ultra light weight lubricants, I'm not sure you'd see a real gain.
I have run 30wt in the rear and tranny on a run or two when I needed "everything I could get at any cost". Of course it all came apart after the race for inspection.
Old 08-21-2011, 05:26 PM   #5
Jason Fuller
Guest
Posts: n/a
Lightbulb Re: electric or gear driver rear end lubricator
Thank you Mr. Wilcox.
I've was considering using a transmission with electric pump eliminating the mechanical one and incorporating it to the rear end.. It's leagal for any internal modifications to the trans but, maybe hard to fit a pump inside of the case...is outside the case still legal?
Old 08-21-2011, 05:57 PM   #6
Jeff Lee
Jeff Lee's Avatar
Most racers, in any motorsport venue, if they have an idea that is "grey area" material, would run it and deal with it if & when it ever (if ever) becomes an issue. I think it's great your thinking out of the box and letting NHRA know what direction to start looking on your car.
Jeff Lee 7494 D/S '70 AMX
Old 08-21-2011, 06:32 PM   #7
Jason Fuller
Guest
Posts: n/a
LOL, Jeff . I don't know if you mean well or that was a stab at go ahead and get caught first. Thanks for the response. I'm always thinking outside the box...I have many things up the sleeve still...Can't wait to start working with a few people on these projects....Not the one mentioned here, others...
