Old 05-26-2011, 07:58 AM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Mopar stick racers with SS springs weight transfer problem
Car: old 90's stocker reborn 70/1 challenger 383 with jerico, dana 60 5.13 with what are believed to be launcher springs in the rear clamped 3 times in the front both sides, none in the rear no pinion snubber.
Car isn't lifting the front end, the rear springs separate rear end goes up and car goes forward. On the upside car even with no 60 foot 1.65-7 can still go under the index.
It looks like a street car leaving. Anyone running a pinion snubber with the leaf spring mopars?
Shall pose another thread asking about cal-tracks for stick mopars.
Thanks
Eric
Eric Merryfield 1883 STK
Old 05-26-2011, 09:41 AM   #2
Bobby Fazio
Bobby Fazio's Avatar
Default Re: Mopar stick racers with SS springs weight transfer probl
What is the launch RPM, first gear ratio, and what kind of clutch? Also, are the tires hooking?
'65 Mustang SS/L & L/SA
Old 05-26-2011, 09:59 AM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I used to run the launcher springs on the camaro up until 4 years ago,what we did is run 4 clamps on each side ,one on the left rear rancho shocks set on 8 to keep down the seperation. You need 6-7 deg. pinion angle to get them to work, if there old they might not work anymore. Went to the caltrac setup sits lower not as much seperation the 60ft. is about the same. They never recommended a pinion snubber My car is an auto.BB. gsa612
Old 05-26-2011, 03:19 PM   #4
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Thanks
Eric
Eric,
Give us a call, Calvert 90-10 fronts and 9 way rears will do wonders.
We can hook you up.
Pun intended LOL.
219-861-1214
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 05-26-2011, 03:50 PM   #5
Steve Hayward
Thanks
Eric
Try this...........
Front end
Loose upper control arm bushings. (Tack the Cams locks in place)
Poly lower Bushings
Koni SPA-1 shocks or better
Loose Strut rod bushings at the K frame.
Rear
Rancho's set on full loose
Control rear separtion with rear spring clamps
Steve Hayward is offline   Reply With Quote
Old 05-30-2011, 07:17 PM   #6
Eric Merryfield
Originally Posted by Steve Hayward View Post
Try this...........
Front end
Poly lower Bushings
Rear
Update:
Thanks for all the suggestions: I did call Alex and order the Calverts shocks front and rear. The prior owner also thought that the new technology would work a lot better. Will try shocks first and move to the calvert bars and springs as needed.
I got the car off the rollback this morning and measured how it sat in the front from center of front wheel to wheel quarter panel edge then jacked up car till the front wheels came off the ground I got 5-5.5 inches of travel.
I didn't check the pinion angle yet , cookout was calling.
Looking forward to playing with the classy challenger again soon. Parts will go on after E-town.
E-town is next for the dakota and the dragpak with Mike behind the wheel.
Thank You to all that memorial day is observed for......including my late grandfather Clarence who served 3 plus years in the Phillipines in WW2, in whos memory the dragpak was built......and all the men and women who have fallen in defense of our great country.....
Eric
Old 06-01-2011, 08:44 PM   #7
Bill Edgeworth
Eric,
It’s fairly easy on those cars to put the front end up in the air remove the torsion bar adjusting bolt and the nut that goes through the arm and check to see if the front suspension moves freely. What diameter torsion bars are in the car?
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 06-01-2011, 10:22 PM   #8
Eric Merryfield
Originally Posted by Bill Edgeworth View Post
Eric,
worn out 6 cyl ones.
shall check into it further next week when back from e-town.
Thanks
Eric
