The new car has an automatic, I know, but what can you do. My question, being I am automatically challenged is: What is the best switch to use for install on the brake pedal for activation of the 2 step? Thanks for any info.
Liked 1,821 Times in 413 Posts
If you're going to mount it in the pedal itself, a Dedenbear adjustable will work.
If you're going to mount it on the pedal arm, in place of the brake light switch, the Biondo/Harrington long throw adjustable will do fine. I strongly suggest you mount a switch on the shifter that allows the two step to operate ONLY in low gear, as activating it down track is not only illegal, but can be hazardous to you, your engine, and your car.
Alan Roehrich 212A G/S |
I use a brake light pressue switch in a port on the line lock solenoid. Let off the peddle and away you go. A switch on the shifter so it works only on low gear is best, no down track excitement.
Jeff
Street legal 64 Falcon Sprint with 410W ![]() Stock - Super Stock fan |
#4 | |
Liked 13 Times in 9 Posts
Personally, I choose to eliminate any such issues, and purely footbrake the car(s), no 2-step.
I use a pressure switch on the 4 speed car but the 2 step is set so high that tapping the brakes does not effect it. The automatic car picks up quite a bit with the two step but I may foot brake it for a bit.
Liked 129 Times in 59 Posts
Just my opinion, but I think in order to make the brake switch/2-step work you're going to need a brake pressure gauge plumbed in there too. This way you'll be able to get some consistency with your brake application.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 8 Times in 3 Posts
Doesn't that put you on the low RPM chip during the burnout?
Liked 13 Times in 7 Posts
Are you saying use the factory switch? Will it work? I have always just foot braked like Michael but I would like the option. I used the switch on my other car once and awhile. I think that it may have improved the et though I never proved it and I liked footbraking better.
Richard Grant 4988 STK |
![]() Wired correctly, it should be your line lock that sets the RPM limiter to the burnout chip. The brake switch, whichever you use, should set the RPM limiter to the launch chip. Both of those switches "off" should set the RPM limiter to the high side chip.
#10 | |
