Old 05-12-2011, 03:56 PM   #1
Mile High
Default Re: Pedal mounted 2 step switch
I use a brake light pressue switch in a port on the line lock solenoid. Let off the peddle and away you go. A switch on the shifter so it works only on low gear is best, no down track excitement.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 05-12-2011, 07:15 PM   #2
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
If you feel you have to use a 2-step, a brake pressure switch is the only way to go. Using a button on the brake pedal is inherently inconsistent.
Personally, I choose to eliminate any such issues, and purely footbrake the car(s), no 2-step.
Old 05-12-2011, 08:48 PM   #3
NHRA1285
I use a pressure switch on the 4 speed car but the 2 step is set so high that tapping the brakes does not effect it. The automatic car picks up quite a bit with the two step but I may foot brake it for a bit.
NHRA1285 is offline   Reply With Quote
Old 05-13-2011, 12:53 AM   #4
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Just my opinion, but I think in order to make the brake switch/2-step work you're going to need a brake pressure gauge plumbed in there too. This way you'll be able to get some consistency with your brake application.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 05-13-2011, 09:53 AM   #5
Lew
Lew, to me, this would seem to be the ultimate in consistent use of a two step on the brakes. If you were to stage every time at the exact same pressure, the distance and time required to release the two step would be the same.
Old 05-13-2011, 10:25 AM   #6
Mile High
I've been using the 2 step since 1996 and I have a switch on the dash. Do the burn out throw the switch then once in high gear turn it off. It's such a habit that while at the Nitro Jam in San Antonio ( footbrake class) I kept reaching for the switch. A brake pressure gauge would probably keep you more consistant . The factory 64 Falcon brake light switch that screws into the master cylinder is what I use.
A friend of mine wired his to the brake light switch on his 72 Nova at first and it worked well. Then he drilled and tapped the master cylinder to use the Ford pressure brake light switch and he says its reacts quicker. He doesn't have a line lock but does use a low gear only switch for the 2 step.
Jeff
Old 05-13-2011, 01:00 AM   #7
hookdaddy
Liked 8 Times in 3 Posts
Jeff
Doesn't that put you on the low RPM chip during the burnout?
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 05-13-2011, 09:14 AM   #8
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Are you saying use the factory switch? Will it work? I have always just foot braked like Michael but I would like the option. I used the switch on my other car once and awhile. I think that it may have improved the et though I never proved it and I liked footbraking better.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-13-2011, 09:50 AM   #9
The factory brake light switch "might" work. However, it is a short throw switch, and not very adjustable. The odds of it working correctly for you are very slim.
Old 05-13-2011, 04:14 PM   #10
Chad Rhodes
Alan, the factory brake switch has worked very well in Dad's car, however I tried to do that in the camaro and it didn't like it at all. I have a harrington button sitting on my desk ready to go in before i come up there
Chad Rhodes 2113 I/SA
